Help... I am probably being comepletly blind here but how do you navigate the site to make transfers between each stages of the Giro? There used to be a transfer option on the menu to the left side but I can't see it there anymore.
Thanks
3 comments
Gkam84 [9119 posts] 7 years ago
The cut off for transfer for today was 11am
If you look up there ^^^ click on fantasy cycling and then when transfers are open it will have a transfers button on the left hand side list, towards the bottom of the list gives you this
Giro d'Italia
Stage 3 Reggio Emilia > Rapallo
Mon May 09 2011, 1100 GMT
Transfers available: 2
So i think 11am will be cut off again
stewieatb [296 posts] 7 years ago
It takes an hour or so after the stage finish for transfers to become available again - it's usually around the time that the stage points come through. When they're available there will be a button in the top left again  1
chiv30 [987 posts] 4 years ago
Yep you guessed it ....bump
