F/S BRAND NEW 2010 felt b2 pro w/full warranty
Brand New, Boxed felt b2 pro. RRP £4500+. 54cm size, these sell out quickest so you wont find these on sale very often.
Spec as below
• Finish - Gloss White/Carbon
• Sizes - 50, 52, 54, 56, 58cm
• Frame - Felt Tri Specific UHM Ultra-high Modulus Modular Carbon Fibre Frame with 3KP Finish, Full Aero Tubeset with front & rear wheel recesses, internal cable routing, forged horizontal dropouts
• Fork - Bayonet II UHM Carbon Fibre Monocoque Design with 3KP Finish, Carbon Blades, Dropouts, Crown & External Steerer with Felt 1 Bearing Compression Device
• Headset - Bayonet 1 Integrated
• Stem - Bayonet II Integrated CNC Machined Aluminium, Rise, -35° thru +43°
• Handlebar - Felt Bayonet UHC-Nano Carbon Fibre 420mm Base Bar
• Grips - Tri-tip Ergonomic Base Bar grip with Felt Gel Ribbon Cork Tape with Felt 3D Logo wrapped extensions
• Shifters - SRAM Aero Double Tap 20 speed Bar End Shifter
• Front Derailleur - SRAM Red braze-on, double
• Rear Derailleur - SRAM RED short cage with ceramic bearing pulleys
• Crankset - SRAM RED GXP, 53/39T
• Bottom Bracket - SRAM compatible External 68mm
• Chain - SRAM 10 speed with PowerLock
• Freewheel- SRAM OG-1070 Cassette
• Brake Levers - SRAM Brake Levers with carbon fiber blades
• Brakes - SRAM RED Dual Pivot
• Cables - Slick Brake & Derailleur
• Saddle - 3.1 Team Issue Tri/TT Saddle
• Seat Post - 3.1 UHM Carbon Fibre Bladed Monocoque Design x 300mm
• Seat Post Clamp - Aero 3D Forged Aluminium, 2x5mmx0.8mm Cr-Mo Bolts, 18 Grams
• Rims - 700c: Front Wheel Zipp 404,16H, Rear Wheel Zipp 808, 20H; All Clincher - custom b2 pro wheelset
• Front Hub - Zipp 16H Front hub with Grade 5 steel cartridge bearings
• Rear Hub - Zipp 20H Rear Hub with Grade 5 Steel Cartridge Bearings, Shimano Compatible Freehub
• Spokes - Sapim CX ray spokes laced radial FRONT/Laced 2x non drive radial drive REAR
• Tires - Vittoria Diamante Pro-Light Kevlar Bead Folding 700x23c
Was £4500, asking £3300 ono
Full warranty.
road.cc on YouTube
0 comments
