4 comments
Hi juan. what kind of bike is it? a bit more info necessary for a detailed reply.
if you've changed the road levers for V-brake ones then you could end up having less power, not more - V-brakes pull more cable so the force at the rim is lower
as for tyres, depends what they are! 2.5bar (37psi) isn't much though. i run 25mm tyres pumped up to 100psi...
ok bike is a (cough cough) 1997 Decathlon cobra 540.
Tyres are michelin 700x23C.
Would a picture help?
You need a good 100psi in those 23c's, if you find you are loosing more than 20 spi over a month, you might need some more inner tubes. Also inspect the tyre itself while deflated for glass that might have worked its way through the carcass. Common commuting headache.
As for the brakes, we just basically need to know what brakes are fitted to that machine. Shimano's newer dual pivot style calipers are normally more than powerful enough to lock road wheels up, even in the wet. Anything more powerful is unnecessary with slick 23c contact patches to work with, though road disks have other debateable advantages.
Thanks very much.
The brakes are 1997 105 the only thing I have changed is the cables (outer and inner) and the lever to go with the "cut" handlebar.
I have just put a new tyre on the bike of the rear one was dead but I couldn't find any indication of rotation is it going to be a problem?
Thanks for all you replies as for the pressure I put 7 bars (around 100psi) in the tube and loose about 2.5 kg in around a month.
Thanks again
Juan
