3 comments
5 foot 10 is 177.8cm, 6 foot 10 is 208cm.
I'm 5'10, with a 32inch inseam. I think I have pretty average proportions and have had a Retul bike fit. I used to go for 56cm toptube but now I'm on 54cm in most brands with a slightly longer stem than normal [110mm]. Given how you describe your dimensions I would look for something more like 54cm, as you can simply adjust the seatpost to a higher position to account for leg length [my saddle to centre of bottom bracket measurement is 730mm with 170mm cranks - sounds like your will be a bit higher due to longer legs].
But the key numbers are the stack and reach of a frame. If I were you I would invest the time to visit a bike shop and ask if you can just sit on a couple of bikes. It's likely they'll give you some guidance on size too. If you can, also make a note of the stem length and crank length. If you find one that feels right, when you get home look it up online to find out what the stack and reach figures are, then that can form the basis for comparing with the bikes you are considering. I've had to unfortunately cross out lots of bikes that just wouldn't fit me!
Best of luck in your exciting search!
I apologise for my mistake above. I compared 5 foot 1 to 6 foot 10. However I should have compared 5 foot 10 to 6 foot 1.
Thanks for pointint it out @bobbydazzler.
Hi Tomaz26,
I don't think 5.10 would be 177cm. It is more like 155.5 cm.
I'm 6.10 (186cm) and I have been riding size 56 for over a decade.
I also have long legs and short torso. So few bikes, I had to shorten the stem in order to make the bike fit me properly.
Not entirely sure if you 155.5 cm or 177cm, either way, I would think a size 56 might be slightly too big for you, or will need some adjustments. Size 58 difinitely way too big for you size I would think.
Some brands would do size 55. I would recommend to reconsider your measurements to ensure you get a right size bike for you. Either a size 54 or 55 should fit you.
As it is your first bike, I wouldn't recommend you buying a bike online without riding one before hand to know the right size.
Maybe use Canyon website, in order to know what bike size would suit you. Then take the geometry of their bike and compare to the ones you want to buy.
I hope it helps.
