12 comments
Nice work, but I think the handlebars fall foul of The Rules.
Good dadding. Looks a bit odd with the brifters stuck up in the air like that but if it works for her it's all good!
I thought that I would post an update on this.
Here are the upgrades that I made to the bike
The following items were used in the essential upgrades:
2006 Islabike Beinn 20
Luath 24 bars (Nearly New)
Claris 8sp Shifter/ Tektro Brake (Nearly New)
Luath CX brakes (Nearly New)
8sp 20" Wheels Shimano 105/Sun Rims (Used)
8sp SRAM 11-32 cassette (Used)
Shimano Workshop Brake Cable x2 (Stock Item)
Unex Ultraglide Gear Cable (New)
Shimano Tiagra HG53 9-speed chain (Stock Item)
New style Isla Beinn Saddle (New)
9sp Sora 3500 short cage rear derailier (New)
8° Shimano Sora ST-3400 Adjustment Block (New)
Rear derailier hanger extender (New)
The following items were used in the bling upgrades:
Purple Seat Post 25.4 X 350 MM (New)
Purple Ferrules (New)
Purple Bottle Cage Bolts (New)
Purple Brake Blocks (New)
Lilac Deda Elementi Bar Tape (New)
Crown Shape Dust Caps (Stock Item)
250ml Purple Gloss Spray Paint (New)
FWE Bells (Stock Item)
Lilac Brake Lever Covers (New)
Purple Reflective Tape (New)
Lilac Crank Bash Guards (New)
72Pcs Spoke Wrap Kit (New)
The total for all the above came to £260 (including the original bike)
so was not a cheap option.
Lessons learnt:
- I needed a longer hanger to avoid hitting the large gear cog
- I needed a shorter arm derailier to avoid hitting the wheel rim
- The new longer seat post should enable a few more years of use
- Adjusting the reach of the brifter was relatively easy with Shimano Shims, the left hand Tektro brake I'm still trying to figure out.
- There is not as much parent/child bonding time while building up a bike as I thought. The only element that she seemed to enjoy was spray painting, picking out bling upgrades and the finished product.
- What I think will look good and what my child thinks will look good are not the same thing
- My daughter will definately be going to the Luath rather than Beinn when she's ready for the next size as she loves drop bars
Bargain!
Most important is to get some really cool bar tape though.
Our two daughters both struggled at the start with Luath 24 shifters, and so would typically leave it in bottom gear as it was so hard to change down again. They wouldn’t have been able to brake or shift on the drop levers at an age where they were riding a 20”. It wasn’t till they were about 9 they would use the drop levers at all, and age 11 with disc brakes older d is able to brake and shift from any position.
CX brake levers on the top will be needed. For shifting, maybe a bar end shifter would be best. Or even both bar end brake and shift!
http://www.jtekengineering.com/products/aero-bar-mounted-aero-brake-lever/
Kidsracing also sell junior handlebars - maybe have a chat with them.
Luckily the eBay Luath bars that I bought have the shifters, cables, bar tape and CX brakes included
i think itll work. I would get too caught up on frame geometries fwiw, the beinn is very short and upright, so drop bars wont really affect too much as the bike is quite short as it is. ive got one (beinn 20) in the garage so im not just "guessing" about the geometry.
the shifting might be a thing i would try to keep simple, either a old style flip shifter: bar mounted, or mount the twist shifter centrally, on the steerer, a few ways to do this, a quick google shows how. not sure that age will be able to work out paddle/flip shifters, i may be wrong
only thing that youll only find out when build is if the steering gets a bit twitchy due to the longer/more forward bars position.
fwiw i bet islabikes ahave tried it out. might want to mail them to what they think
gl
We've found that when they move up to the Luath, their hands are still a wee bit on the small side for the shifters/ brakes (twist grip on the Beinn is so much easier for small hands). if your daughter is still Beinn sized (with concomitantly small hands) I suspect she would really struggle with the drop bar shifters (and brakes). Move up when good and ready!
Good point. My daughter has exactly this problem with the drop levers on her Luath and uses the cyclo-x levers almost exclusively.
Whilst it's not a totally crazy idea, it's not a very good one. The problem is that flat bar and drop bar bikes have different geometries, and most importantly for you a flat bar bike has a longer top tube. What this means is that you have to shorten the stem significantly to have a reasonable riding position with drop bars. But this affects the steering.
Now I have done this with an adult bike, and whilst it works, it isn't ideal. But I really wouldn't try it with a childs bike, the stem is much shorter in the first place and I doubt it will be possible to shorten it much further. So your daughter will end up with a stretched position, which probably won't endear her to the idea of riding drops.
I thought the same thing and did a little bit of investigation and rough estimation. The length of the top tube on the old Beinn 24 model (same year as the one I have) is halfway inbetween that of the modern Beinn 24 and Luath 24. I used the 24 model as comparison as there is no Luath 20 to make a direct comparison to the Beinn 20.
