7 comments
I'm 6ft 3, and ride a 58cm Supersix with a 110cm stem, although can get away with a 120 mid summer when the back loosens up a bit from time in the saddle. 58 sounds about right for you, especialy as the Synapse is a touch shorter/higher than the supersix.
Worth measuring up your position on your current bike though and checking the reach is achievable on the 58 while keeping the saddle tip - bb centre distance the same. Moving the saddle fwd to change your reach will likely upset your knees.
I'm 6'0" with average body and leg lengths, and spent a most enjoyable week over Easter on a 56 cm Synapse (rim brake model) in Gran Canaria. It felt quite upright in comparison to my medium sized Canyon Ultimate, I'd have liked to have taken a couple of spacers out. I could possibly have gone for the 58, although I didn't try it, but I think I'd have wanted to take all the spacers out and I don't think it would have felt too long. Don't know how much that helps you, but I suspect 58 is your correct size.
The 58cm should be the best choice. Like rando, I'm 6ft 1" and relatively long legs and I rode a 58" Synapse for a few years. I had a simple bike fit on it and similarly ended up moving the seat fowards and fitting a shorter stem (90mm).
I am 6ft 1" with a 36 inch inseam and was measured for a 58cm on a Cannonadale Synapse. Also all legs with a short body !
Currently have a Trek Domane 60cm.
a 56" will be too small for you.
Thanks peted76,
I'm glad my logic isn't totally flawed then
Most bike shops suggest you go for a smaller frame if unsure but even though Cannondale generally come up with a longer top tube I didn't find I was overstretching when the seat was brought forward.
That alone made me question whether the tradeoff of a smaller frame was worth it and it sounds like it might not.
OK, I'll trial the 56 as it is in my shop now but will probably go back for the 58 if I'm not happy with the position - thanks again!
M
You're 6'2" .. go with the bigger frame and a shorter stem.. a 56 isn't for normal people sized 6'2".
You 'should' really get fitted out, most decent shops will fit you up before you buy or when you buy, this usually includes stem swap outs.. so you can leave a shop without too many worries of fitting. Worthwhile for you and your long legs and shorts arms IMO.
