3 comments
You can do most of the adjustments including firmware updates with the battery charger, the other box is primarily for diagnostic work.
If you have a braze on mech the support bolt sets the angle of the cage. Band on mechs can be rotated to set the angle, although the latest Shimano mechs state you should use the support bolt to do this.
As I understand it you can't downgrade firmware on Di2 kit so not sure what's going on with the versions.
Strongly recommend that you read the Shimano dealer manual (not user guide) - they're excellent and include all the information you need to set up your group.
Ignore the videos and just follow Shimano's clear written instructions on the paper manuals provided with each piece of equipment. 6770 and 6870 are different groups and do not share the same setup.
> Isn’t the fixing bolt just for height only?
No, hence the shape of the braze-on.
> Said differently, can it be used to make the outer plate parallel?
Yes, a bit.
> If so, how do I do so?
Loosen it, move the derailleur until it's in the right spot, tighten it.
> Should I assume I have already gone through and adjusted the high limit at some point in time to get it parallel?
The limit screws don't set the angle of the derailleur. They just stop the cage moving too far in either direction.
I apologize for the delayed response. Thank you very much. Your insight is appreciated.
