Hi looking for some advice. The lower bolt on my Sram Rival 10 speed medium cage jockey wheel is seized & the bolt hole is starting to round & the wheel itself is worn - I have a replacement wheel & bolt but how do I get the old one out?
Thanks.
7 comments
StraelGuy [1358 posts] 2 months ago
You could drill the head out of the existing bolt. Use a bit about the same diameter as the shank of the bolt. Once the head pops off you should be able to rotate one of the plates aside and get the remains of the bolt out with pliers. Have you soaked it in penetrating fluid yet, that might help?
huntswheelers [131 posts] 2 months ago
on the bench..... use an "Easy Out".... screw extractor.....we use them all the time(mainly of FSA crank bolts as they are sh*t and soft alloy) ... use the pilot drill and then lightly tap in the screw then turn it anti clockwise... and the bolt will unscrew.... pop a bit of grease on the thread when you reassemble
Duncann [1281 posts] 2 months ago
Remove the derailleur and soak the inner (spoke) side in penetration oil as suggested. Leave it an hour or two, maybe overnight. Doesn't always work but it's just a few threads on that side (at least it is on Shimano mechs) so shouldn't need much loosening.
If that fails, escalate to the alternative above. "Easy out" sounds good.
Butty [258 posts] 2 months ago
Soak in plus gas overnight and then with top pulley bolt undone, try rotating the whole rear cage plate against the seized bolt.
Butty wrote:
Soak in plus gas overnight and then with top pulley bolt undone, try rotating the whole rear cage cage against the seized bolt.
This is a good tip - if you can remove the upper bolt then you can use the inner cage plate to rotate against the screw (rather than the other way around). Plenty leverage.
Boatsie [230 posts] 2 months ago
Penatrine (sounds as read not sure regarding spelling) is a really good fluid. Spray as best you can into thread and leave to penetrate overnight. Penatrine pretty decent if really stuck. Can lightly tap head to loosen up a bit. No Thor strength required, just a tap tap.
Easy outs as suggested. Locking pliers if rounded. Both. Either or.
Main guts is to get lube into thread. Soak as mentioned or spray and let soak in.
When bolts are tight and won't budge, often it pays to crack there threads by initially tightening them just a smidge. Loosens threads by tightening, get oil into them and then loosen the bolt. Add oil first!
A mixture of ATF and acetone is supposed to be the best penetrating fluid there is. I made two bottles recently in a fit of enthusiasm so, if by any chance you're anywhere in the Manchester/Liverpool area, you're welcome to a bottle!
