FS Thule EuroWay G2 921 2 Bike Towbar Mounted Carrier 7 Pin Connection
Hardly used and in fantastic condition
Comes with instruction manual and 2 keys
Product description Exclusive and comfortable lightweight bike carrier for towbar mounting (for 2 bikes) Rear Bike Carrier Thule Euroway G2 (2 Bikes, 7 Pin Electrics) Take the bikes with you this holiday using the Thule Euroway G2 2 bike carrier for 7 pin electrics. Features: Fits 2 Bikes 7 Pin Electrics Easy fit Compact and foldable when not in use for easy storage Load capacity: 46kg - max per bike is 24kg Each bike is secured with its own arm that holds the frame. Strap with micro quick release buckles for quickly attaching the wheels Large tilt angle for opening bigger tailgates, even with the bikes in the rack Practical tilt pedal for easily accessing the boot, even with your bikes fixed in place Indicators Brake lights Position lamps Registration plate light Lockable (2 keys provided) Product set up: Length: 102 cm Width: 55 cm Height: 78 cm Product folded: Length: 102 cm Width: 73 cm Height: 26 cm RRP £290
£180
https://i.ebayimg.com/00/s/NzY4WDEwMjQ=/z/ljkAAOSwn~JapWwv/$_86.JPG
