6 comments
That cap bit is dual function - it’s octalink one way round and threaded the other - you take the cap off, reverse it and slide it into the hollow octalink axle, or leave it on to protect the thread. Or take it off altogether if the axle takes nuts rather than bolts.
However, most crank pullers have a chamfer machined on them that’s enough to prevent the end of the puller distorting the thread...
I'm with you. The cheap tool kit I bought just touches the threads when pushing the arm off. I need to spread the load. I've asked the old man; a retired fitter and turner, to build me a tool: a scrap bit of tube welded to a washer.
I'm ignorant of other bottom bracket types. Hoping other newbies recognize what they have and don't ruin or need to read tap their equipment.
Thank you with the advice guys/girls.
Park ccp-2.
And its much easier to remove rhe chainset to change the chainrings. You might need a park cnw-1 to hold the other bit other than the hex side.
Do you have a link to the crank remover you are using? They're pretty simple really. The body of the tool should screw into the cap threads and the inner part of the tool should push against the end of the axle - not a lot to go wrong really.
I understood that. My argument is that the inner part is just a tad too little diameter and touches on the axle thread. If the tools inner bolts diameter was 2-4 mm (guess) wider the the face upon which the bolt pushes is much sturdier and I can reduce my risk of damaging the bottom bracket axle thread.
The thread was pushed on during the initial removal of the arms. Heaps of thread there. Not risking the damage. Just weighing up options..
Cheers ktache. Park ccp-2 looks easy. I think taking a spare crank arm into the LBS could be my go, size up a wider pushing face if available.
Welding a washer if they're dear though
Found this.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2F...
That cap bit a heaps better idea than a welded washer. Could lube the tool!
I think I'll search scrap and use a washer and tube. I haven't a clue why the thread protector isn't included in the cheap tool boxes. Best bit.
'That cap bit' is available seperately but will wreck your cranks, it's an adapter for hollow octalink type bottom brackets and won't go through the sqare taper. Your tool is an old design for bottom brackets which had external threads and nuts holding the cranks on, not bolts. I've got one of these which works really well https://www.decathlon.co.uk/bike-crank-extractor-id_8350528.html the smaller diameter just fits through a square taper and the step works for octalink.
