Any file recommendations please?
For brake pads - taking the glaze off.
Seeing as I'll be heading to Toolstation for some thread lock, what kind of file should I be looking at? My current ones are nabbed from old toolboxes, have no handle and are past their best.
12 comments
Woldsman | 6 years ago
 I use P120 sandpaper. Having blown a rim on a rear wheel I've become been especially careful to look after my rims and brake blocks. I keep meaning to get a hook and pick set to winkle out the little shards of rim fragment and other junk that the pads pick up. (Screwfix do a set by Teng.)  I'm not sure that a file is necessarily the best tool for the job.
RMurphy195 | 6 years ago
Fine sandpaper (120 grit), have it on a flat surface,hold the pad flat on it, and then rub the pad across the sandpaper, not the other way round.
BarryBianchi | 6 years ago
The block paving on my drive is perfect.
kevvjj | 6 years ago
I just use the concrete floor...
peted76 replied to kevvjj | 6 years ago
I like this man ^^ he gotz the sense.
Grahamd | 6 years ago
I just use my stubble.
CXR94Di2 replied to Grahamd | 6 years ago
We don't know if she is hirsute or not  1
youngoldbloke | 6 years ago
Just use emery boards (as used for fingernails).
Canyon48 | 6 years ago
Pretty much anything.
I used 250 grit sandpaper. Don't use anything super fine like polishing sticks or wet and dry though!
StraelGuy | 6 years ago
I think you're overthinking this dottigirl. Any fairly fine to medium file would do the job perfectly.
Leviathan | 6 years ago
.xls .doc .gpx and .jpeg are all my favourites.
theironduck replied to Leviathan | 6 years ago
Wot no .tcx?
