5 comments
Can't speak for the Mavic front wheel as mine is QR, but service for a standard QR rear wheel is dead simple. From memory, you remove the cassette, then put a spanner over the nut that should be visible on the driveside and an Allen key in the driveside axle end. You can then remove the axle end and the whole axle can be removed.
There are 3 cartridge bearings in a Mavic rear wheel (2 in the hub to take the rider's weight and one in the freehub). There's also a bushing in the freehub. This normally needs a service long before the bearings (a few drops of wet lube is all) so a new freehub might be in order if this hasn't been done and it's rough. Otherwise, replacing the bearings is the same as any other hub based around cartridge bearings
have you tried using a magic wand and saying abracadabra?
This didn't work for me on my mavic wheels, I had to do it the muggle way
ah, good thinking - might be mavic and an unhelpful spellchecker
aren't mavics sealed bearing units though? - I think all you can do is use the special (but non-magical) tool to undo the units and clean out any crud
Levering off the dust seals from the cartridge bearings and repacking them with grease is often all it takes to rejuvenate a hub, but if it's already sounding distressed, who knows? It might be worth a try.
There are loads of YouTube videos showing how to mock-up an extractor/press to help with replacement.
Best of luck.
