8 comments
It will work I replaced mine with dura ace just case of bleeding up levers on other hand are different m7 thread as opposed to m6 on calipers and old levers
john, to be clear, you fitted dura ace callipers to replace some RS805s? Did the hose fit the calliper? It seems to be a different diameter.
SAB
The hose answers are correct ^ (Have looked into this in depth with a Shimano expert and Dura Ace hydro which is basically the same situation). Using the wrong hoses may make your brakes either super rigid feeling or super spongy depending on which way you get it wrong.
I went through this recently fitting 685/805 hydraulic brakes. Those two hoses are slightly different diameters. The BH59 is the older, slightly wider bore and uses the olive and brass end fitting kit whereas the BH90 is the newer, narrower standard and uses the olive and silver end fitting kit.
So, i would need to put in new brake hoses. That probably means the levers will need the BH90 hoses, so i would have to change them too. So then the Ultegra disc brake callipers arent a replacement for the 805s.
I wonder if you can make the BH59 hose fit. More digging!
According to this Shimano compatibility chart it appears you can. Click on caliper model to compare specs. http://productinfo.shimano.com/#/com/2.7?cid=C-460&acid=C-461
that is a good chart. There is lots of info in there. Good find!
Hmm, when i look at the chart everything seems to be the same except for the hose. My RS805 uses an SM-BH59 hose, but the new ultegra R8070 uses SM-BH90. Not sure what the difference is. Need to do more digging.
