Fitting 4 year old Campagnolo Veloce to a new frame
After a recent failure of my Mderckx EMX1 the Merckx company have sent me a brand new Sallanches 64 frame.  Whilst this is very nice of them it has caused some issues.   Obviously time has moved on and Merckx now supply all their bikes with Shimano.  So compatabiliy issues exist between my old groupset and the new frame.  There are three main issues
1. Seat tube diameter - no big deal I need to buy a new seat tube.
2. My front mech is band on but the new frame has a hanger - can I modify the old mech or do I need to buy a new one?
3. bottom bracket - I'm really at a loss here.  The new frame has a  50mm diameter shell which is also wider at approx 80mm than the old one.  assuming I buy a new BB will I be able to use my old crank and do I need adapters etc?
sorry if these questions seem stupid but I've never done this sort of bike build before
Thanks
6 comments
Dr Livingstone | 6 years ago
checked the mech - just band on - new one abut £28 so not terrible
Jack Osbourne snr replied to Dr Livingstone | 6 years ago
Front mechs are without doubt the only cycling components that offer consistently reasonable value for money... Except the motorised ones!
dottigirl | 6 years ago
Some of my band-on mechs were actually braze-on with an adapter band fitted - I just needed to unscrew the band part. Worth checking?
Good luck - sounds like a nice build.
Thanks Jack, that is tremendously helpful
Jack Osbourne snr | 6 years ago
1. Correct - you need a new seat post
2. You can't turn a band on mech without masses of uneconomical re-engineering. Your only viable option is a braze-on.
3. Your new frame has a BB 86 shell. Assuming that you've got the powertorque Veloce chainset, you need a set of Campagnolo BB86 Power torque cups. If youre new to building a bike from scratch, get a shop to supply and fit them for you as press fit bottom brackets can be challenging.
Everything else should just bolt on without added fettling.
problem 2 sorted - I need to buy a new braze-on front mech
