7 comments
Fully agree with you. Thought I could be missing something due to inexperience. I asked how the tool removed the cups on the video but Unior just referred me to the presumably Slovenian-English passage I pasted here.
part_robot, I think Hambini only deals with 30mm bb's amd conversion to 34mm spindle.
Unfortunately all mute as a driver decided to turn across me without braking, cutting a corner, crossing the lane and hitting me head on at 30mph. Still, no bones broken and admitted full liabilty. Just gotta battle for a new bike now...
I strongly recommend hambini.com for all bearing needs. The guy sells very well made and affordable tools and has been extremely accommodating with my various custom requests. Has a good YouTube channel too.
Just use a flat punch and tap around bearing at 12 O'clock then 6 then 9, 3 keep going bearing will come out no damage or expensive tools. Refitting use large bolt/nut with big washers, you can also use the old bearing to keep even pressure
Well that's what I thought, thanks. I have actually seen that video but the literature does explicitly say it removes the cups.
This tool is designed to remove the non-threaded bottom bracket bearings and cups of the BB90 bottom bracket system. It also supports other press fit standards with 24mm spindle, such as BB86, BB92, SRAM Press Fit GXP. The removal tool will pull the bearings & cup from the frame. Carefully insert the guide head of removal tool trough the bottom bracket cup (marked green).
I read that too. My Specy has Shimano cups measuring 11mm thick x 50mm diameter. The video didn't satisfy me with the ability to pull cups along with a bearing, especially with a short bolt and the tool barely covering the BB hole. With cups usually larger than BB holes I just don't see how they can be removed with this tool. But that's just my opinion and I may be wrong. What I couldn't locate were Unior specifications on the tools depth and width/diameter. Perhaps you can.
"I fear the tool would only extract the bearings and not the cups"
Unfortunately it is a yes, it is designed to only remove the bearing not the bearing AND cup. The Unior bearing removal bolt is not long enough to compensate for the added cup length. This YouTube video shows @ 0:11 the length of the bolt and @ 0:15 hand tightening the retaining nut with two turns.
https://www.youtube.com/watch?v=MQBJB5ZoKYw
That's what it looks like
