48 comments
Myself and a mate did the Maratona a few weeks ago. He had some brand new Giant carbon rimmed wheels and had no problems at all. We also descended Campolongo in the wet before the event and he said braking performance was very good.On our way to Italy we did some riding in France at temperatures close to 30 degrees with steep descents and again no problems.
Well, having done three ascents via the three routes in three days I can honestly say that ventoux is one of the best places I have ever cycled. Could I have used carbon rims? Possibly. Was I glad not to have to worry about it? Absolutely!
Glad I listened to the advice given, and if anybody else finds this while trying to answer the same question, the answer, in my mind is simple. Take the aluminium rims!!
Oh, and if you do go to ventoux, make sure you ride the gorge de la nesque - incredible scenery!
Cheers,
Rich
Just a little FYI for all engineers in here (armchair, desk chair, and control chair):
"At Zipp we built a machine we called the ‘Chariot of Fire’ to try and understand all of this during our carbon clincher development, and it used a 400-lb. flywheel driven by an electric motor and could simulate most any type of downhill situation, different rider mass, and could even be programmed with real-world descending situations. It could also simulate environmental conditions like heat, cold, or rain. We found that the worst thing you can do during descending is prolonged, constant braking; the rim never has time to cool so the temperatures continue increasing at some pretty unbelievable rates. Even giving the wheel 2-3 seconds of rest during a test could drop temperature by almost 100 degrees F."
Read more at http://www.velonews.com/2015/02/bikes-and-tech/technical-faq/technical-f..."
There's a bit more there. But my takeaway is that for those really big mountain days (ie. attempting to join the club des cinglés), alloy is a great choice, particularly if it gets hot. Have fun!
Thanks for that. I said originally I'd be happy to change my view on receipt of good engineering evidence.
View cautiously changed.
Love to know the engineering basis for the result
I'm more of a desk engineer, but if you're asking for a theoretical model, I'm afraid that just the thermodynamics are well beyond me. For starters you've got some kind of a convection-diffusion situation where the relationships between the variables are expressed in differential equations and nothing is easy to tease out. And then there are so many other things. Material-wise, you might also have something like a positive feedback where inter-surface adhesion between pad and track might also increase as a function of temperature, just to name another possible non-linear interaction to consider. Aerodynamics are never linear. Friction is linear but gravity causes acceleration, which then impacts the aerodynamics.
I'd venture a guess that gerally the faster you go the more the air both brakes you and cools your rims, but that might be up to a point where other things come into play if you pick up plenty of speed and then brake too hard. But ¯\_(ツ)_/¯
So yeah, "Chariot of Fire". It may seem like an appeal to authority, but for my money good old-fashioned experimentation is a very sound engineering basis.
Chrs. Looking at it from a physics point of view, regardless of speeds attained, at the end of the day you are getting rid of the same amount of potential energy (from top of the hill to bottom) so it would seem to me that the slower you need to disperse that energy (i.e. taking longer to get down the mountain) the slower the transfer of energy to the rim, hence allowing more time for dissipation (and the differences are pretty big. On ventoux an averag of 60 kph -which from strava seems 'normal'- transfer time is 20 mins, at 40 kph it's 40 min, at 20 kph it's 1 hour). I would have thought that is more than enough time to dissipate the heat, but it would appear the convective effects are substantial (which on a thermodynamic basis I'm struggling to find a reason for as there's no evaporative agent, so the heat dissipation should be straight line-ish). Thinking as I go, I guess maybe the tyre acts as a radiator....
Just few points on this, to hopefully keep you from going down the rabbit-hole:
a) I doubt heat dissipation is straight line-ish. For one, even before evaporative effects, I doubt the airflow effect on heat transfer is insignificant (or linear). Also, consider heat dissipation in the pad vis-a-vis the rim. When you're pressing the calipers together you're cooling the pad with the hot rims and viceversa, instead of cool air. But, again, ¯\_(ツ)_/¯
b) (edit: this has been said, but) While conservation of energy establishes that kinetic energy must equal potential energy loss, not all of the potential energy is lost the same way. So the air resistence on the rider does part of the work without giving off heat on the rims. When you're going 80kph, even on a relatively steep descent you're being almost completely airbraked. Mechanical equilibrium is reached through that, and not the heat producing friction on pads on rims.
c) Again, this is somewhat of an appeal to authority, but I think that the fact the Zipp engineers, whose thermodynamics knowledge surely far, far, far outweighs mine, chose to explain it on the basis of experimental data seemingly untethered to a theoretical framework might be a sign that they might be at least a bit unsure about it as well.
Good decision, as you said prev, you've no real experience of riding on long, really fast descents where you'll likely need a shed load of braking and you don't know the terrain and how much actual braking you'll need. Your riding enjoyment won't be lessened any by using the Mavic's but you'll have a little more to fall back on and you'll come away with a better idea as to what works, what doesn't (for you) and if in the future you could get away with using carbon rims on similar.
better to learn with a side of caution and move forward than destroy an expensive pair of wheels at best, at worst, well, you know how things can go wrong when you have no braking on high speed descents.
Enjoy.
wow, loads of information to take in, thank you all.
I have decided that discretion is the better part of valour, and I'm fitting my kysriums so I have an alloy rim. As was said ealrier in the post, if it is playing enough on my mind to ask a bunch of strangers on the internet then it would probably make the whole descent more worrying than need be!
As for my skill set, well I'll be there next week, so I will find out - having nothing to compare it to, I have no idea, but confidently cautious is my usual approach, so that should work out ok.
Thanks for all the input - it made for interesting reading!
Rich
Enjoy
Regarding the tech:
Pro wheels don't fail at 120kmh because they use tubulars which have much thicker material around the braking area which can handle and conduct away considerably more heat. Meanwhile the clinchers used by the rest of us are thin because the brake track is (with very few exceptions) in the same region as the clinching. Don't use pro bikes as a reference point; carbon clinchers can and do fail and no brand is immune. Plus the pros are better than you at handling their bikes and already know the courses.
Sorry to say but carbon clinchers really are dumb and nothing more than a gimmmick to part us from our money. Get a lightweight aluminium aero pair like Hunt Aero Road, one with a carbon fairing like the mid price Mavics or just do the sensible thing and get a bike with disc brakes
End of.
I've carbon Cero RC45 Evo and alu Fulcrum Racing Zeros.
Experience has taught me that when I go to the high mountains then the Zeros go on.
Better safe than sorry.
I've done the Maratona a few times, EDT, Majorca 312 and a couple of weeks in Girona and Chamonix on a pair of Boras. No issues whatsoever. I'm in the "descend fast, brake hard" camp.
Don't drag the brakes all the way down and carbon rims are fine.
Got back from the Alps two weeks ago. My friends Vision Metron 40s melted descending Col de Sarenne, leaving him with no brakes (pads shredded) and having to get a lift to the bottom of the mountain. Real world experience.
Hi
I have new Campag Bora Ones Carbon rims and Campag Neutron Ally's.
I'm using the Neutrons for the MAratona on Saturday.
Reason being I've done a couple of Etapes in the past (2010/2011), the Marmotte in 2013, Challenge Vercors 2014 and Ventoux Sportive last year.
On the first three events I've seen puncture's and destroyed carbon rims probably due to over braking/ dragging brakes.
I've done a reasonable amount of riding in France and subscribe to the descend fast and brake hard theory to allow rims time to cool. However when riding in the bigger sportives there are so many riders about the a certain amount of rim dragging is inevitable as you have to take account of other riders speeds and cornering lines.
Also the weather looks sketchy for the Maratona and the braking performance of the Neutrons is streets ahead of the Bora's in the wet despite the "new, improved" braking surface.
Only my opinions though.
Cheers - enjoy the event!
I think Martyn is on the money. whether or not you are going to push the rims, if you are concerned, I'd chuck on a set of alloy rims and be done with it.
If I was going for a cycling holiday in the mountains, it would be my choice... as said above, purely so its something that I won't have to think about.
Let's roll this back a little and forget about all the armchair engineers. Reflect and take a look at yourself, you are obviously concerned hence the questions.
I'm by no means a fast descender but enjoy a downhill and will progress through corners with as much speed as possible. I ride 45mm carbons as an everyday wheel and weigh in at 67-70 kg (time in season dependant!).
In the Alps last year the bike had alu Campag Zonda's fitted for peace of mind. I'm sure the carbons would have been fine but i did not want to take the risk. I ride in Majorca every year so am happy with descending for a longish time (compared to UK) but alpine drops are another level.
You need to ask yourself if you will be able to dismiss this doubt you are having. Coming down large mountain passes at speed you need your whole focus to be 'in the moment'. You need to process your speed, the feel of the road, shape of the road, oncoming dangers etc etc.
You don't want to then have the additional variables of 'should i brake now or later on these carbon rims?', 'How mush braking have i already done?', 'Are the rims heating up?'. Small lapses in concentration on mountain passes can result in not so small issues.
Bang a set of alu's on the bike. Have peace of mind. Know that if you need to drag the brakes you have a little more wiggle room. At the end of the day having a great trip and having awesome stories to tell is much more important.
For the record comparing club riders to pro's in this circumstance is a chalk and cheese approach. Pro's have closed roads meaning that they have 50% more tarmac to play with. More tarmac, equals easier cornering, equals less braking.
To be up front, I've not used carbon rims, so have no direct experience. However, I rode the Ariegeoise today and most climbs were fog bound so the roads were a bit sketchy. You need a lot of nerve to brake hard on roads like that. I saw 4 carbon wheeled bikes upside down with their owners carefully turning the wheels. It looked like they were looking for rim/brake rub. Didn't stop to ask though, so may have it completely wrong. My route had a summit finish and we were moto escorted back down to the event 'village'. It was a measured pace, let's say, so you couldn't do the "fast down, brake hard" option described above, and based on the noises there was a lot of brake dragging going on. The guy in front of me had his front wheel rim deform. On the same event two years ago, in similar conditions, I helped out a guy roadside whose front wheel had started to deform. His only option was to open out his front brakes to stop them rubbing against the rim.
My take from all this is that carbon rim brake wheels are likely just fine if used considerately, but may be more prone to failure if not. Conditions may mean you can't do so.
Just one Internet user's observations and inferences, worth what you paid for it.
All depends on your confidence level if you brake alot on decents in the UK then in the Alps I wouldn't ride carbon.
I'm not that confident decending when we did d'huez last year I was the slowest down. I wouldn't run carbon some of the decents are over 20k and my wheels were a little warm. I have to force myself not to brake drag.
I had a similar concern for a recent trip to Mallorca; ride carbon clinchers (DCR premium rims) or swap to alloy rims. Took the carbons and all turned out fine. Probably not as testing as ventoux/alps though but they survived descending Sa Calobra for 10km behind a line of cars (constant braking) with no fade at all. I'm 68kg and by no means confident going downhill; much prefer going up!
Mind you I've had a cheaper set (chinese) delaminate in the past but couldn't pin point when that happened or why...My guess would be that with half-decent rims and reasonable technique it should be ok...
FFS don't make this about cycle helmets
And watch this https://www.youtube.com/watch?v=ET1jRVynOBA and its sequel.
There are a fair few slopes in the UK you can hit 50mph whilst being 'sat up' so that isn't enough, you must apply some braking otherwise on slopes such as the one the OP is attempting could mean they are still going to be going faster than is safe for them or what they feel comfortable at.
As I posted previously regarding choice of descents, I agree with your 'smaller hills' comment. Getting into bother on high speed slopes can have horrendous outcomes and there was one here on road cc from in the UK where it seemed apparent the rider bit off more than they could chew and paid for it dearly.
A friend of mine came off badly three years ago in Spain, luckily only knckering his knee and a severe concussion..
This is part of the reason why I think cycle helmets are dumb, too many get overconfident and wouldn't take as much risk without a helmet.
See far too many close calls in the last 10years or so, nothing like it used to be. Overtly aggressive and much higher risk too often ending in a spill is the norm these days
Good advice on technique above (except the keep braking between corners suggestion, don't do that) regardless of rim material. To which I would add, if you want to slow down between corners, sit up. Wind resistance will limit your speed. Then get in the drops for the twisty bits.
If you're not confident transitioning between tops and drops at speed, pick smaller hills.
When I was in Tenerife on a cycling holiday one of the chaps had a lovely Pinarello Bike with some Enve carbon wheels. After one day of descending Mt. Teide, he was down the local cycle shop to hire some basic alloy rimmed wheels. He was very concerned how hot the rims were getting under long repeated braking periods. He thought his rims would delaminate or tyre explode.
I on the other hand, had carbon wheels with disc brakes and had no issues at all
The problem with carbon fibre composite rims as compared to Al alloy rims is
that CFC does not have a specific heat capacity anywhere near that of Al alloy.
What this means is that if you apply a certain amount of energy by way of heat
to a certain mass of CFC, it's temperature will rise considerably more than
the same amount of energy applied to the same mass of Al alloy.
That scenario is what happens when you're going down an alpine pass. You're
scrubbing of your speed big style and the energy you have is proportional to
your mass and velocity. You "lose" that energy when you apply your brakes but
it is largely gained by your rims resulting in a rise in temperature of the
material that they're fabricated from.
Al alloy: No probs. Large specific heat capacity. No failure of the rim or
glue attaching tub to said rim.
CFC: Big probs. Low specific heat capacity so the rim gets hot enough for the
matrix material in the composite to melt - it's just some shitty old polymer,
after all. Result? The walls of the rim fall apart, your tyre comes off and
you faceplant...if you're lucky. If you're unlucky, you'll go over the edge
and an ambulance will come along and scoop up the bits of you they can find at
the bottom of the valley.
I hear people saying: "But the pro's ride CFC rims".
Sure they do. But they're paid a pile of money to do so; you're not.
Actually CFC has a higher specific heat capacity than alloy (1.1J /gdegC on average cf 0.9 J/gdegC for alloy). The conductivity in alloy is the key to the heat loss. Alloy will cool down faster.
Your described result is very different to the real world experience of most people using carbon composite wheels.
The amount pros are paid has nothing to do with the likelihood their wheels will fail as you've described. And they like to do it day after day, their livelihood depends on it so they're not going to do it on something that fails with the certainty you've described.
As for pros going down faster and not braking as much: they corner at 'similar ' speeds to a good club cyclist (what you'd go round the corner at 20 mph, they'll do at 25 mph; however they're slowing down from 60+ mph instead of 45 - 50 mph, which means they actually do 60% more (energy loss from) braking, or allowing for your club cyclist to be 20% heavier (85kg vs 70kg) they are still doing 45 - 50% more braking; so if it can stand up to the pros, it can stand up to a club cyclist (YMMV)
You seem to have quoted a figure for aluminium which is not necessarily the
same as when it has been alloyed with whatever.
Ditto with CFC. The heat capacity of the fibres can vary wildly as can that of the matrix material.
Quoting average figures is completely worthless because the distribution is so wide.
Correct. It's why the heatsink on my GPU in this computer is made of Al alloy.
Wake me up when they make them from CFC.
Pray tell me: what percentage of these people with CFC rims ride up and down
alpine passes?
Mavic's real world experience seems to considerably differ from yours.
They're busy flogging CFC wheels too, so it's hardly in their interest to
mention such damning stats.
You're entirely wrong. The pro's will do whatever is required of them if you
bung them enough money.
Shoot up with whatever the latest performance enhancing drug is without giving
a rat's arse about the physical damage it could be doing to them?
Sure. They're young men on the make and every man has his price.
If they were told to do Alpe D'Huez on a Raleigh Chopper having ingested a
truckload of Ritalin, they'd be more than up for it....given suitable
financial compensation and being told by the team manager that "You want to
get along in the team, don't you?"
You're pulling figures out of your arse again. There is absolutely no reason
why I can't get up to "60+ mph" coming down an alpine pass if I choose to.
At least I can stand assured that my wheels aren't going to come apart when I
come to brake.
To cover your original point again, alloy rims have a lower specific heat capacity than CF, and this has nothing to do with their ability to not over heat.
Incidentally, my basic engineering tells me that Energy is proportional to speed squared, so if braking late and hard as suggested by many (to allow the rims time to cool down) I think is probably not good advice, as ultimately the rims have to get rid of more heat (as speed will have built up more in the interim). A safer approach would be to not let your speed get so high in the first place, but still corner as quickly as you can (to reduce the amount of speed loss required). I'm quite happy to be put right by someone with good engineering knowledge. I imagine it is possible (but I think unlikely) that the rate of heat transfer through the carbon may affect the answer.
You are neglecting the air braking energy dissipation. The more energy lost to wind resistance the less that has to be lost through the brake pads. By braking as little as possible speed is kept up and less energy heats the wheel. After all at the top energy is proportional to elevation. This becomes kinetic and then becomes heat either in the air (dispersed and negligible) or in the brake pads and wheel.
The worst thing to do would be drag the brakes and descend the entire mountain at 20kph.
Pages
