5 comments
Hi, I've just done this on an sl4. I went with the praxis works osbb to shimano adapter. I think it's the best option. Easy job. The are video on YouTube.
From what I can tell, Spez OSBB comes in two flavors, largely dependent on your frame material.
Aluminum frames are marked "OSBB" but are BB30 in reality - the metal bearings go in and are secured with circlips.
http://wheelsmfg.com/specialized-alloy-osbb-tech
Carbon frames are still marked "OSBB" but are a modified version of PF30. The bearings sit inside plastic cups, whose outer lips stop them from sinking too far inside the BB shell - hence no need for circlips. It does need some spacers in addition to the PF30 cups though.
http://wheelsmfg.com/carbon-osbb-tech
Both BB30 and PF30 (and by extension, all flavors of Spez OSBB) are built around cranks with 30 mm spindle diamters. All Shimano cranks have 24 mm spindles, so a reducer adapter is needed.
It's not a pain in the arse to replace though? I wore out the BB in my SL4 and replaced it with a C-Bear ceramic unit. Piece of piss to source & replace.
The fitted BB is designed for 30mm axles and Shimano don't make them - hence the need for adaptors to reduce the size of the BB.
It's not hard.
Take a look, there's even an OSBB section for you - https://www.c-bear.com/en/osbb
Wow, they're using the same trick as for their proprietary Mindset headset? Ignore any industry standard and install something which is a PITA to replace, with associated further expense.
Utter penny-grabbing bastards.
In order to use a crankset other than Specialized you need to purchase a set of adpater cups (plus shims) such as these by Wheels Manufacturing. Why? Specialized has an OSBB (over sized bb) larger than Shimano/Sram/Campy. Thus the need for cups.
http://wheelsmfg.com/bb-pf30-universal-adapter-for-24mm-spindle-cranks-s...
For a complete conversion (entire BB) see Praxis Works
https://www.praxiscycles.com/product/shimano-conversion-bb/
