Hi,
I currently own a pair of Mavic Ksyrium Elite S (2013) wheel set. The bearing inside the freehub has now worn out and I need replacement bearings. But there are so many bearing models that I'm not sure which one would fit my case. I got myself the 608-2RS bearing model, but the inner diameter is too small and it does'nt fit in the hub axel. Can you guys can help me out with the model number or the dimensions of the bearings that goes with my wheelset freehub? Thanks in advance
3 comments
Nat Jas Moe [175 posts] 10 months ago
If you remove the sealed bearing it's normally written on the bearing itself, using those details you should be able to order its replacement.
dottigirl [811 posts] 10 months ago
Yep, check the bearing you've removed. Depending on how degraded it is, you should still be able to read the writing.
Out of curiosity, how are you removing/installing the bearings?
Ogi [136 posts] 10 months ago
