6 comments
good point - I forget to check my calipers are moving freely, having said that I dont remember ever having a dual pivot seize up, they seem very low maintenance
I rode open pro CDs until they wore thru (nearly) and the braking never diminished. I can't think of any reason they should (unless they are ceramics, but once you were thru to the alloy surface you should still have relatively good braking). I think the gunked or jammed calipers / cables is most likely as you've changed the blocks too. In 35 years of riding I've never had brake performance reduce due to rim wear.
Are these Mavic Open Pro "ceramic"? Ceramic braking surfaces have a tendency - when braking in wet - to polish/smooth the surface. If not, I still would do as others commented.
heres my checklist when brakes arent as good as they should be -
Are the pads aligned correctly on the rim? sometimes taking the wheel on/off can knock the pads.
Are they balanced i.e wheel doesnt deviate when brakes applied
Are the pads / rim clean
Are the pads old and need replacing?
Does the cable need replacing, if so when was the cable outer changed last?
If all this is ok then see if you can borrow a wheel to see if the rim makes any difference (ive got a second wheelset so this makes it easier).
I'll take a look at the cables, it is on my winter bike, so it does take a bit of a battering.
Have you looked at the cables. I have had this and it's been a case of ceased cables and gunked up calipers. Just a thought.
