7 comments
I know this is an old thread... But,,, I have the 2015 Kysrium Elite S wheels and wanted to know the same thing(Max tire width). These have been a bulletproof set of wheels for years. I had to do some digging to find out what the max tire size was on the Mavic site. The serial number lookup sucked. So I had to download all manuals the years before and after the year that I bought my wheels, just to be sure. My Kysrium Elite S wheels were only made in 2015.
Here are the specs .
Front and Rear wheel specs
Specifications RIMS
▪Material : Maxtal
▪Height : front 22 mm, rear 25 mm asymmetrical
▪Joint : SUP
▪Drilling : Fore
▪Brake track : UB Control
▪Weight reduction : ISM
▪Valve hole diameter : 6.5 mm
▪Tyre : clincher
▪ETRTO size : 622x15C
▪Recommended tyre sizes : 19 to 32 mm
Here are the links to help anyone out trying to find the same information for other years.
2015 Manual (Only the S model is listed in 2015 Manual)
https://tech.mavic.com/tech-mavic/technical_manual/data/docs/catalogues/...
2014
2016
2017
the little booklet you get with mavic wheels says 15C can run 23-32mm tyres - I tried to find an online version to link, but haven't found it yet
Thanks for the responses.
I have the S' so going off what you've said then Anthony the internal width is 15mm.
Given what everyone else has said above I imagine that rules out the wider tyres on 15mm width.
However can we assume I would be able to run some 27/28 tyres without issue?
If your wheels are Mavic Ksyrium Elite S then they will be 15 mm rim width not 17 mm. Mavic dropped the S for the newer version of the wheels and they are 17 mm width.
You are correct in assuming the narrow internal width "has some bearing on the max tyre width." A few years back I mounted 25mm Michie Pro 3's on the same rim only to find the sidewalls ballooned out to a measured 27.5mm. But, and I say but, because Michie Pro 3's were notorius for measuring wider than spec'd so I cannot attest that this would happen with another tire mfg.
However, I see no clearance problems with 27's on your frame. The 32's are questionable. Perhaps if you took your rear wheel to your LBS, along with a digital micrometer, they would allow you to mount a 32 and measure its width. I would do this with the mfg tire of choice as width may vary from mfg to mfg.
one mavic chart I have says they'll take 52's but on the mavic site it says, 25-32mm
I've ridden 28mm conti's on a 15mm integral width rim with no issues. I'd imagine 32 would be okay on 17mm
