Adjusting saddle angle
My bike (Mongoose hybrid) has a single bolt for the saddle clamp: I've been trying to get the saddle a bit more nose up (ideally level, but y'know...).   So I undo the bolt, adjust the saddle, then tighten the bolt again.   Except that as I tighten the bolt, I can actually see the nose of the saddle move down again.
Is there something blindingly obvious that I'm missing here?
5 comments
Roadie_john | 7 years ago
Nose up is the way to go for me too. Not by much, but definitely just up from the horizontal.
brooksby | 7 years ago
I realised after some fiddling that I had to loosen the bolt a certain amount to open up the clamp and move the saddle fore/aft, but then had to loosen it quite a lot more to be able to freely change the angle.   I've now got the saddle set quite far back, and the nose is pointing ever so slightly up.
StraelGuy | 7 years ago
Don't let others judge your bike setup. What works for you works for you. I have my saddles pointing slighty up on all my bikes.
CXR94Di2 | 7 years ago
Yes, set it slightly too high and as the bolt tighens it will pull it into the position you desire
brooksby replied to CXR94Di2 | 7 years ago
Thats great! Thank you.
