Leg warmers for large thighs
Can anyone recommend some leg warmers, I have outgrown my large ones I think I bought cheap on the net the band at the top now cuts into my leg too much. Having just measured my thighs I have a 24 inch circumference. I'm 5'10 and have been hitting the gym quite a lot since knee surgery. Cheers in advance.
6 comments
fenix | 7 years ago
I usually go with winter longs in the proper winter - but we are at that annoying time of year - can be very chilly early on and then nice in the afternoon - so leg warmers do have their uses.
Heck 2 weeks ago I was in shorts for rides - in 2 more weeks it might be full on winter kit. Who knows ?
StraelGuy | 7 years ago
I'm glad you brought that up dottigirl. As a relative newcomer to cycling, I've often thought the same thing. If you know it's cold and you're likely to need arm or leg warmers, why not wear a long sleeved top and full length tights in the first place  .
gthornton101 replied to StraelGuy | 7 years ago
It's just down to flexibility for me.  Often it's colder when I leave early but I warm up so want to have the option of taking arm warmers off (which a long sleeve base layer doesn't allow you to do).  Likewise with knee warmers.
Also, I have many short sleeve base layers that I use in spring/autumn and a cheapish pair of arm warmers makes them equivalent to a long sleeve base layer without spending too much more money.
Staying on topic, +1 for dhb to suit larger legs.
dottigirl | 7 years ago
With winter coming on, I'm already in tights. I never found a comfy pair of knee or leg warmers, and have never seen the point of shorts plus warmers for a cold day - why not just wear tights or 3/4s?
Rapha Nadal | 7 years ago
Pearl Izumi make some good ones that are suitable for the larger thighed gent.  Quite a bit of give in them but tight enougjh to not look baggy, if that makes sense.
Jack Osbourne snr | 7 years ago
Dhb. Generally the fit is more suited to the larger athlete. Large should work for you.
I'm 5'11" and have slightly bigger thighs.
Personally, I prefer a pair of unpadded tights over the top. I have a pair of Nike running pants I've used for about 12 years. Only slightly bulkier than Roubaix leg warmers when rolled up in a pocket and soooooo much less of a faff to get on and off in changeable weather.
Edited to add: I prefer overtights but have tried warmers in a couple of flavours. I had a pair of Lycra ones from Shutt VR that were frankly, only fit for a sparrow.
