9 comments
I have a Power2Max and a PowerTap SL+ wheel that I've built on to a number of rims over the years. I also used to have another PowerTap that was on my old commuter bike.
Given you have a standard 68mm BB shell, you can fit pretty much any crank based power meter using various bottom bracket types. The Power2Max I have is the Gen1 BOR688 with 30mm spindle, and I'm using it with the BSA cups and some Enduro angular contact bearings.
Something like the Power2Max or Quark would be my choice if I bought another one.
For you, you can use your current 8-speed chainrings, and have the potential to swap the crank onto a new bike, or add different chainrings if you upgrade the drivetrain.
The crank based power meters have the benefit over a powertap that you can have many sets of wheels. And, to me, given the rate that I chew through pedals, I don't want my power meter to be a disposable part of my bike.
An alternative to the Powerpod is the original product the iBike Newton used by tinkoff . I also have the Garmin vector pedals very easy to fit.
Comparing the vector and ibike Newton they report very similar numbers, the only time I see a difference is when I am going downhill when ibike often says zero.
unless you are a pro rider I don't see the need for very accurate numbers and if you can save money by sacrificing a bit of accuracy why not
I just bought a powerpod - Can go on any bike and easy to swap between bikes.
Some people don't like them, but it seems good to me so far...
I came with an ace of buying one when the Kickstarter funding was started but wanted to see how it progressed 1st. Always a bit wary of buying somehting that hasn't been tested by "real" people.
I like the look of it though I have to say.
Only issue the person in our club had with a powerpod was in groups or during races. Apparently the way they work is using wind measurements so if you are sat directly behind or in a group you may get varied results. There is a DCrainmaker review on this (really good for powermeter reviews)
I've read his review, it's very comprehensive.
The whole group riding thing doesn't bother me really as I'm usually out on my own.
Hi,
A Stages SRAM Rival compact might be a good combination for you. I've found my (non-Stages) crankset easy to fit and reliable (just one new GXP BB after 2 years, 2nd one still going strong).
I can't say the same for my Powertap SL+...it is quite old though.
As @philhubbard says - limited by the BB & cranks - other than a pedal-based system the other alternative would be to build a wheel with a PowerTap hub (or similar)...
Hi, because of the chainset you are using you are going to be severely limited in choice. You would probably have to go for a pedal-based option.
If you wanted to go for a crank based option such as a Stages powermeter you would have to upgrade your chainset as well, potentially to something similar to a 105 level.
