Help Advise
6 comments
DJ AL | 7 years ago
Thanks for the reply. It is the modern version. I plan on taking it to a bike shop for an initial tune up, but I was hoping to purchase a carrier for them to put on. I wanted to "have a choice" if possible. But that idea seems to be fading!
Eric D | 7 years ago
Sounds like taking it to your local bike shop (maybe even Halfords) would be best.
Is it the vintage model from the 1940s?
Or the modern one ?
Either way it probably needs hands-on experience : good luck !
DJ AL | 7 years ago
Like I said, I have a Columbia Compax 26" folding bike. Does anyone have one? If so, what model carrier are you using? I want to  put a pannier on it. The way the frame is made, where the seat inserts is not "round" so I cannot mount anything there. Since I must keep the seat as low as it will go, I cannot mount anything on the round seat pole. Sorry, if (terminology) is not correct. The easiest answer, would be if someone already has this bike. What model carrier are they using?
Thanks
If you 'view source' you can see the intended message:
meta name="description" content="I purchased a Columbia Compax 26" Folding  Bike. Not a mechanical person. I purchased a rear carrier that wasn't compatible with the bike and I returned it. Does anyone have this bike? If so, what make and model carrier do you use. Not: I can not raise my seat, as I need it at it's lowest point. Therefore I don't think I can use a carrier that attaches toaround the seat base (not round). Help appreciated !   AL"
Don't you speak HTML ?
If the road.cc guys ever read this:
Make 'Content' a required field ?
So the form can't be submitted with it empty ?
Remove the 'Summary' field !
tritecommentbot | 7 years ago
Hah. He typed in the first box!
Griff500 | 7 years ago
Care to be more specific?
