9 comments
11-28 works no problem with a Short Cage 105...... I did one yesterday on a Dolan....
there must have been some issue with your set up
There's no reason you shouldn't be able to fit an 11-28 cassette. I can't really imagine how changing a cassette could knacker everything as you've said.
AKH,
That was a big concern about the frame and wheel, somehow my wheel avoided any damage and frame has afew marks on but nothing major. I am just going to drop back down to 11 - 25 as that ran fine. My chain is bent, almost snapped in half! Also its ripped the cable from the bottom of the derailleur so its going to be cassette, derailleur chain and a cable! Adds up really looking at £110 for everything from wiggle!
Cheers for the help
Huh. Did you start out with an 11-23?
Hi mancsi,
I've been in exactly the same situation as you before. In my case, not only was the mech trashed, but also the rear wheel, and the frame was damaged.
As you're going to have to replace the rear derailleur, you might as well start from scratch with the cassette you prefer; you’re going to have to re-index the whole lot anyway.
GCN do videos on installing and indexing a rear derailleur. Well worth learning as it’s a simple task when you get the hang of it, and it’s something you’re likely to have to do if you change wheels or cassette.
How to Change Your Rear Derailleur - Replacing Your Bike's Rear Mech
https://www.youtube.com/watch?v=CPLiW-0zLa4
How To Index Your Gears - Adjusting Your Rear Derailleur
https://www.youtube.com/watch?v=Bbk5RcH0bbQ
As the rear derailleur has likely collided with the rear wheel, check the spokes for damage and check the chain for any bent plates. If I were you, I’d replace the cable at the same time. I replaced the fancy teflon coated cable that came with my 105 groupset wth a basic stainless steel one and it’s been absolutely fine.
Good luck.
I didnt change my chain but wasn't shifting from big to small in wild ways. I presume that may have been the issue the as when I just ran through all the gears, big ring and small cog would jam slightly. Makes sense.
Cheers Phil
You'll definitely need a longer chain when getting a larger cassette or chainrings. I've been there. Not changing means you're putting more tension in the chain, and stuff that's meant to withstand that tension will eventually snap.
While you're at it, do try to get Wheels Manufacturing rear derailleur hangers. They're machined 6061 aluminum and are usually stronger than the stock hangers.
I presume you changed your chain as well and didn't just go from your big ring into the largest cog on your cassette? If so, your chain will have been too short...
The only thing I can think of is that not loosening off your b-screw a little when increasing the size of your cassette has caused something to go a bit awry. But I'm not sure this would have caused your hangar to snap off.
