7 comments
It will give you slower steering, but be more steady at low speed. What also matters is where your weight is relative to the headset. If you set everything way back (like a sit-up-and-beg) the steering slows down because you are no longer "on top" of the steerer tube.
But first, what about the position of the saddle nose relative to the botton bracket? I replicate that setting before I try to fix the distance from the nose to the bars. Otherwise, I just naturally sit further back or forward on the saddle and my body position changes.
Yeah you're right chaps the winter big has a way too long top tube, I think the combination of age and injuries has made it more noticeable, it used to be fine (like most people it's my old good bike, a giant tcr)
i just want to get some use out of it to save my good bike. I didn't really realise what long legs and a short back I had until I had the Retul done
I'm just trying to adjust it close to the Retul as I can.
After a few miles you will of adapted to the different steering feel, job done ☺
First instinct is as YW says above - the frame is too big. Putting the saddle so far forward will affect your pedaling too - part of the bike fit should have included fore/aft saddle position.
Regarding steering, as long as your bars are still 40cm+ width, it shouldn't be too twitchy.
Sounds like the winter frame is the wrong size.
I've switched from a 100mm to 60mm...and am still alive. Can't say I notice this as being unduly twitchy and certainly not life threatening. I don't think an inch or two makes a difference
It will be fine, if you have bars with a longer reach then you can afford a shorter stem. In fact you can run the stem backwards and it will still work - true!
That's because it's the rake and the trail which actually makes a bike sharp or slow to steer, not the stem, though you'll certainly notice the difference between a very short or a very long stem.
