3 comments
B screw adjustable. Generally you don't need to worry too much going from 28t to 32t
Suggest you check for chain stretch as chain length for 11-28 & 11-32 cassettes are the same. Also interesting is you're not getting cage rub against the lager rear cog.
A practical method to see if chain is too long or short
When on the small ring on the front and the small gear on the cassette, the derailleur should still be applying a little tension on the bottom run of the chain.
Now when on the big ring on the front and big ring on the back, the derailleur shouldn't be fully stretched forward.
Now your setup, going from 28 to 32 will not induce slack in the chain unless a longer chain was fitted. It sounds like it's normal, just check the derailleur has a little bit of tension and hasn't run out of play
