6 comments
Unfortunately not
Does your lezyne pump have a pressure release on it which may help prevent this?
I had tightened the valve core using pliers on the outer stem and a core removal tool on the inner. I tightened it as much as the tool & core would allow.
Unfortunately, the rubber seal on the Lezyne pump I purchased is very tight (obviously tighter than the seal between the core and the stem), therefore unscrewing the core whilst removing it......
The problem will go away as soon as I start using tubes without removable cores!!
They will be fine if you carefully tighten the core properly with a pair of pliers - it only unscrews with the pump because it wasn't in securely. I've used Conti and Schwalbe tubes for years and the only time I this happened to me was after using valve extenders.
Thanks!! Michelin's are now on order
Michelin Airstop or FWE from Evans.
