13 comments
I recently had a crazy amount of clicking coming from the headset/handlebar area.
I removed the bars and cleaned all the clamping surfaces, greased the threads of the bolts and reinstalled taking particular care as to how I tightened the bolts.
This solved my particular problem, I guessed that all the sweat I had dripped on the handlebar stem during a week in the Alps had caused it!
Hi chalky I replaced all the spacers as the original ones neither fitted the stem nor top cap very well!
Dunno if this will be of any help. I had a clicking problem with my Giant. Like you, I thought it was coming from the headset, and, like you, I re-greased the bearings but the clicking persisted.
I took it to my LBS. After a few turns the guy traced it to the cable-end housing on the top tube. It was simply a case of the cable being fitted far too tightly and every time the handlebars were turned it caused the cable-end to click in the housing.
Edit: Try releasing or slackening the cable then turning the bars to see if it persists.
I never thought about the spacers, they are the type you describe with the 3 little nodes, I have it set up with all the spacers under the stem, did you put one on top just to suit you or solve the click. Thanks for the help.
My new Cannondale was clicking from the front end when pedalling hard and I tracked it down to the stock carbon fibre stem spacers which were the 'reduced' style (the inside milled away leaving 3 points of contact) after I noticed these had a poor contact / fit against the underneath of the stem, and the stem cap. (I setup the bike with spacers under stem, and on top of stem).
The only item I've changed were the spacers, to "solid" carbon fibre spacers, and the clicking went away
On my previous bike, I've also had cable outers developing clicking when turning the bars, replaced these and no problem again.
I've also had the cable housings click which needed a regrease of the inners and where they locate in the frame.
Also had the stem/bar interface click which needed new bars to fix...
Both times I thought it was the headset bearings that were knackered but they ran smooth when I had removed them.
Cheers will try that.
All headset/bike bearings are not made by the bike manufacturer but are generally off the shelf bearings so can be bought from bearing suppliers
Remove the bearings and you should see a code on them
Take the bearing to a local bearing stockist like BRT Bearings and they should be able to match them up
http://www.brt-bearings.com/index.php
Should work out cheaper and be a bit quicker
Try Qwerty cycles. They sell Cannondale bearings. Bought some myself recently.
Thanks for the info and link, they just sell a complete headset, but will email them to see if they do the bearings on their own. It does click when pressure is put on the bars, undulations etc. Thanks again.
Have a look here to see what parts are required
http://www.cannondalespares.com/Cannondale-Headsets/product_subcategory/34
Bearings if rusty could click, grind under load but feel Ok in the hand. Best practice is change them out lubricate all surfaces and see what happens
