19 comments
So how are the Hy-Rds? Big improvement or not so much?
Should have 'em fitted tomorrow, so I'll keep you posted
Had a couple of rides on them now. All good. Really powerful (compared to the Renders) and lever throw doesn't seem as bad as many reviews seem to make out.
Thanks again for the help and advice everyone.
If you are using 'wavy' rotors - ditch 'em. You don't need mud shedding on a roadbike, and the wavy cutouts just create noise and weaken the feel. Fitting Hayes continuous rotors over the standard TRP wavy ones made a huge difference.
And yes, both were set up correctly and burnt in.
Hi ginger, that was what I meant to imply; Internet messages don't always read like I want them too. All I meant to say is that the link suggests that there's no physical reason why you can't use 140s but it's not a good plan
My fault, didn't read your message properly!
I'm also looking to upgrade from renders; I looked into the juins; they say you can run 140s. They just don't recommend it due to heat build up. Check this link for more info
http://www.edgesportsuk.com/store/index.php/juin-tech-r1-hydraulic-cable...
That link seems to suggest that it is a bad idea to run 140mm discs... I ended up getting the Hy/Rds because there is a 140mm option for those (couldn't find them in the UK, but found them on a German website).
The cx77 (and BR517 : same brake different paint) work very well in my experience. Downside is that they need 3 different sized ale keys to adjust them but otherwise they Re effective and low maintenance. Regarding the rotor size, that is mostly determined by the mount on the frame so if you have a 140 on the back then it shouldn't be a problem. You can use an adapter to size up To a larger rotor but not down.
"However, am I right in thinking that the Hy-Rds are worth the extra dosh?"
I got fed up with adjusting BB7's and despite being a bit cynical about a combined cable/hydraulic system I ignore my unfounded prejudice in favour of all the good reviews - my opinion was well worth the extra - you get a lot more performance than the extra cost - feel similar to full hydro on my MTB
Don't leave your bike upside down though - I did after getting a lift home with it wheel less on back seat - next day there was a horrible whistling noise when turned the right way up - checked and apparently they do vent to the air and will suffer if left upside down
EDIT ***as above on the Juin (which get good review) need to check if will work with 140mm, mine came with 2 x 160mm rotors possibly because that's what I ordered or it may be no 140mm option**
Cheers for the advice everyone - gone and bought me a set of Hy-Rds
Go full shimano hydro
I'd love to but I'm not fancying stumping up £silly on levers as well as calipers.
Juin Tech R1s get a good write up and look a bit neater than the TRPs. Also a bit cheaper.
Apparently the Juin brakes aren't compatible with 140mm discs, although I can't think of a reason why that might be!
It could be that the calliper offset is sufficiently large that the pads don't contact a 140mm rotor even if they're bolted directly to the mount without an adapter.
Didn't think of that - clearly I'm a bit dim...
Hy-rd if you don't mind the look (I think they're kinda butt ugly). Then after that bid say the grp spyre as it pushes the pads from both sides instead I'd just one like the shimano and avid bb7 brakes.
Forgot about the Spyres - cheers for the heads up.
