10 comments
Does anyone know if its possible to use an old shifter dismantled so as to have just the small buttons, to use as a hacked climbing shifter? I'm on Ultegra 6770.
You can plug into hoods or fit a 5 way interface. Advantage of 5 way is, for example if you fit time trial clip ons with switches, it's easy to remove later. For a more permanent fit run cables under new bar tape.
No, it would only be of use to have them as extra buttons, I spend 70+% of my time on the hoods tbh.
Some useful information in those links, I hadn't clocked that the sprint and climbers shifters were different things.
I've got the hydraulic ST785 STIs so sprint shifters are an immediate no-no (they miss the connection). It seems I'd need to buy a 5-port dura-ace junction box to get the extra port for the climber shifters (have the 3 port ultegra one atm), which turns it from a relative cheap thing which I might do for giggles - to a much more expensive proposition.
Didn't you want to try without the main shifters though ? That should work.
http://road.cc/content/forum/134597-di2-satellite-shifters
Should be fine from what i've heard/seen, as they're a shifter switch in their own right and not slaved to the STI like the sprinter shifters were e.g.
http://carltonbale.com/shimano-di2-everything-you-need-to-know/
That said, i've not tried it.
It's on my list of things to look into, I quite fancy the idea of the climbing shifters. Would be a good road.cc article:
Extending your Di2: how to's for d-fly and the climbing shifter
Don't you just get a different junction box to add shifters. My Ultegra Di2 came with a junction box with 3 plugs, but I see in the manual you can get them with 5, which I assumed was to add shifters.
If this is the case, you'd just plug the additional shifter into the empty ports.
That doesn't answer your question at all, does it
I doubt it as doesn't the climb shifter need to plug into the actual shifter?
You could possibly use the xtr or alfine di2 shifters though
