Advice on replacing spokes myself?
I have a few broken spokes on my rear wheel. I want to replace these spokes myself. I don't want to take this into a shop. Once I learn how to do this, I can save money in the long run, even if there's an investment in tools now.
I'll also need to true it after that. I got a truing tool a few years ago and have experimented with that.
I carry potentially up to 250 pounds on my bike. That's the limit for the specs on the bike I believe. Over time, spokes wear out. I upgraded the rear wheel becuse of that and the spokes wear out a lot less often.
Wheel model:
Hub model:
Shimano RM30 -- This I found on a specs list for my original bike, listed under rear hub. When I got the wheel replaced, the bike shop must have kept the same hub, I think.
Shimano Rear hub, Fh-2200 36H Silver
http://www.amazon.com/Shimano-Rear-hub-Fh-2200-Silver/dp/B005LY3Q7O/ref=...
This is exactly what I have.
Upgraded rear wheel:
mavic wheel cx 7 22
-- I can't find the exact specs for this online. I found a post saying Mavic doesn't list the spoke tension.
My bike specs in general:
http://www.bikepedia.com/quickbike/BikeSpecs.aspx?year=2009&brand=Raleig...
2009 Raleigh Detour 4.5
Original wheel specs...
Wheels HubsFront: Joytech Alloy QR,
Rear: Shimano RM30 RimsWeinmann XM-260, 36-hole
Tires 700 x 35c Kenda K-192 w/K-shield
Spoke BrandStainless, 14ga. (2.0mm) Spoke
NipplesUnspecified
I've watched a few youtube videos. I understand the general process but I'm wondering which tools and parts I need for sure.
General process:
Remove wheel from bike.
Remove inner tube and tire.
Remove wheel rim tape?
Pull the cassette off. One broken spoke is on the cassette side.
??? Which tool do I need with my Shimano Fh-2200? I think it's a free hub, but I got bogged down in whether it's a free wheel, cassette, hub, etc... That tool isn't expensive, but I'd rather get the one I know works for sure. Or maybe I don't need a special tool to remove the cassette? I see FR-1, FR-5... They all kind of look right.
Along with a hub tool to get the cassette off, I'll need a gear wrench, the arm with the bike chain piece to pull on the cassette? Any specific one?
And then replace the spokes, true the wheel, put it back together.... Hope the shifting is about the same. Adjusting the shifting precisely is something else to learn.
How do I know what to get for spokes?
Wheel rim tape -- I need to buy more of that and retape the whole wheel? (And cloth tape because it's double walled I read.)
I have a double walled wheel. Do I need a nipple tool?
http://www.amazon.com/Park-Tool-373-216-Nipple-Driver/dp/B00F665S5K/ref=...
Chain whip? Does it matter which one? Are they specific to the cassette somehow like the hub tool is?
http://www.amazon.com/Park-Tool-Sprocket-Remover-Chain/dp/B003YUJEF0/ref...
Spokes? I saw I'll need to figure out the measurements. I've got the broken ones and the rest are still on the wheel. Could I just measure those to avoid lots of calculations?
-- Where do I buy spokes? Can I get spokes exactly the length I want somewhere? Premade/threaded ones?
-- Can I measure the spokes that are on my bike now somewhere to get the diameter?
Spoke thread tool? I think this is what the video mentioned...
http://www.amazon.com/Hozan-Spoke-Threading-Machine-C700/dp/B000C3F5LY/r...
This is one of the main reasons I'm asking for advice. I saw a youtube video that said you buy the spoke (generic length I'm assuming, but a specific diameter), cut the spoke, and then have to add the threads on yourself. Fine, except the tool that adds the threads is $140. If that's how it is, that's how it is. Do I need this tool, or can I get spokes that have the correct amount of thread on them already? Is it really an issue if there's too much thread? I just wouldn't wind it that tightly. Possibly, I'm thinking I could buy pre-threaded spokes from someone else. If I'm breaking 2 spokes/year, I could just buy a pack of 10 pre-threaded spokes possibly. But if I have to make them myself, then the sooner I buy this tool, the more I save in the long run.
Spoke/nipple grease?
Would vaseline or oiless bike chain grease work or do I need something special?
Spoke tension measuring tool?
http://www.amazon.com/Park-Tool-Spoke-Tension-Meter/dp/B000OZDIGY/ref=sr...
-- Initially I thought I'd find the spoke tension in the wheel specs somewhere and use this to get in the ballpark. Then use the truing tool to make everything more precise.
Dishing gauge? I'm really doubting I'd need this. I'm only missing three spokes.
http://www.amazon.com/Park-Tool-Portable-Wheel-Dishing/dp/B00426GY4Y/ref...
If it really becomes too much work or expense, I'm thinking I could always take the bike to a shop. Or, I could just bring the rear wheel in and have them replace spokes and true it. Or, I could buy pre-threaded spokes from someone possibly, and do the rest of the repair myself.
This spoke repair looks potentially doable for me. I can replace a tire, inner tube, shifting and brake cables. I've messed with adjusting the shifting a little but gave up. I'd like to get spokes as another repair skill and then I can finally get the wheel truing down better... which will allow the brakes to be adjusted better.
Any ideas or advice on all this? Thanks in advance.
7 comments
turboprannet | 8 years ago
freebsd_frank - thanks for the wheelpro link, I ignored Gerd Schraners soldering suggestion but felt most of the book was a good start.
I'll check wheelpro out.
I do think a tension meter is a sound investment though. It's possible to build a perfectly true and dished wheel that is too slack or tense, either of which carries risks.
freebsd_frank replied to turboprannet | 8 years ago
turboprannet writes:
Yes do and I do very much recommend the book for anybody repairing/building
wheels. Roger Musson's book is also clearer IMO.
I can see the benefits maybe for a professional wheelbuilder, largely for
repeatability purposes but people have and do successfully build wheels
without one. When I first bought his book and built my first set of wheels
c1997, he didn't mention the use of a tensiometer.
It's worth reading what Roger Musson has to say about the matter:
http://www.wheelpro.co.uk/support/tensiometers/
He mentions there that Mavic and DT specify very different spoke tensions
for their respectively similar rims: similar section, similar material etc.
I suspect in practice that there is a fairly wide range of values for tension
of spokes that is acceptable for any specific rim.
Shades | 8 years ago
If my wheels off the bike my friendly local mechanic sorts it while I wait for 10 quid. It'd probably take me all day and he whizzes round the wheel tweaking the spokes in no time at all.
I like DaSy's advice.
I have built some wheels in the past and my opinion is that for the money you save in the long run you will require a significant outlay in tools to complete the job to a satisfactory manner.
The tools you will need are:
- spoke key (£5)
- wheel dishing gauge (£20-£40)
- spoke tension meter (£50+, I feel it's essential)
- wheel truing stand (optional, £30-£000's) - you can make do with some cut of zip ties on your chainstays maybe.
Then your chain whip, lockring tool etc.
You can find which spokes you need using a spoke calculator database, a good one is Edd (http://leonard.io/edd/) which has a wide range of hubs and rims on there which can help you calculate the necessary length of spoke to buy.
You can find a copy of Gerd Schraners book online for free/cheap. Very useful in understanding lacing and tensioning.
I feel you will need to do as others have said and slacken the whole wheel, replace the broken spokes and pay attention to how they cross as the crossing aids tension.
The dishing gauge ensures the wheel is level between the dropouts and that your chainline is correct.
The spoke tension meter will aid you in setting the correct tensions, there is a much higher tension on the drive side which create the dishing.
Then true the wheel in a stand or using the zip tie method.
It is a time consuming and sometimes frustrating process to start with, with a large outlay, or giving it to a mechanic.
I personally find it very enjoyable but I've found it takes longer than you'd set aside and can be a bit annoying.
It may be easier to pay someone else to do it if you don't feel you'd recoup the money spent on tools. However you do learn a great set of skills.
bikerbobbbb writes:
Spokes shouldn't "wear out" in a properly built wheel in normal usage. As long
as you don't go
down a pothole or subject the wheel to loads in excess of that for which it is
designed. Spokes are made from stainless steel and won't fatigue fail if
properly used ie. the stresses are kept below a certain threshold.
Almost certainly has 2.5mm holes, although I'd check on Shimano's site. 2.5mm
holes are fine for 2mm spokes.
mavic wheel cx 7 22
Do you mean wheel or rim? Check the label on the rim, that doesn't look
correct.
If it's a 36h touring rim on the Shimano hub you mentioned it should be strong
enough.
I'm currently building a 32h DT RR440 rim back wheel and it's rated for
an all-up weight of 120kg (ie. over 250lbs even though it's got less spokes
than your wheel and is a low section light racing rim).
NipplesUnspecified
If I were you I'd rebuild your back wheel with the correct length double
butted spokes from a more reputable manufacturer: DT Swiss or Sapim. Use DT
Competitions or Sapim Race and brass nipples. You'll probably use 12mm nipples
unless your rim is deep section which it probably isn't.
Buy Roger Musson's book available at:
It will cost you 9 quid but Gerd Schraners book is out of date and wrong in
places eg. he believes in tying and soldering spokes and his method for
stress-relieving spokes will damage hubs with cartridge bearings. Roger's
book is kept
up-to-date (you get the updates free once you've bought it), it will save
you more than that in tools and Roger will answer any
questions you may have.
To remove the cassette, you'll need a chain whip (there's not much to them, so
I'd get a cheap one), a tool to remove your cassette lock ring (it's circular
with splines on it. Make sure you get a Shimano compatible one) and a largish
shifting spanner.
Cassette lock ring tool:
http://www.chainreactioncycles.com/park-tool-cassette-lockring-tool-fr5/...
You'll also need a spoke wrench. I like the Park one:
http://www.chainreactioncycles.com/park-tool-spoke-wrench-sw/rp-prod17510
Get a black one for the European spokes you're going to use.
That depends if you've got stick on tape (like Velox) or polymer rim tape
which usually isn't stuck on. If it's stick on, you'll have to buy new.
Measure between the walls of the rim or the width of the old tape to order up
the right width.
No. You can get away with using an appropriate screwdriver; it just takes a
bit longer to lace up the wheel. Hopefully, your rim has double eyelets. This
makes building the wheel easier as you can't lose the nipples in the rim!
I wouldn't measure the lengths of the spokes. For one, it's not that easy
because of the elbow and secondly, they could be the wrong length. You can get
spokes in packets of 18 at Chain Reaction. You'll need two packs, each of
differing lengths for drive and non-drive side. BTW, it doesn't matter if you
eg. use Sapim Races one side and DT Competitions the other. Just buy the right
length depending on price/availability. Also, there's no functional difference
between black spokes and silver spokes, it's just fashion. Silver spokes are
cheaper.
The dimensions of your hub: I prefer to measure with
spring dividers and steel rule rather than get them somewhere off the 'net.
You also need to measure the ERD (effective rim diameter) of your rim. How to
do this is all mentioned in Musson's book.
Once you've done that you can just plug the numbers into the wheelpro
calculator to calculate the spoke lengths needed. His calculator knocks off
0.3mm off the length calculated strictly by the trig equation, as he finds
this works out better in practice.
Some motor oil or three-in-one will do.
BTW, you don't need a dishing tool (just swap the wheel round in your jig
instead) but Musson's book shows you how to make one from cardboard.
You don't need one. You'll find that if you calculated the spoke lengths
correctly, the spoke will be near correctly tensioned when: the spoke is at or
near to the head of the nipple; the spokes start to wind-up more as the
frictional forces between spoke and nipple become greater due to the
increased tension in the spoke; the rim starts to go out of shape with small
part-rotations of the nipple(s). You can also pluck the spokes to find any loose
spokes and to compare tensions with a known good similar wheel.
If you don't build with enough tension in the spokes, you'll find that after
riding it for a bit it will go out of true. Then it's time to stick the wheel
back in the trueing jig and get out your spoke wrench and put a bit more
tension into the spokes.
In practice, I've found that even my first set of wheels that I built using
Roger Musson's method never went out of true or broke spokes.
If you're worried about the tension in your spokes, you could always try and
borrow a tensiometer from your LBS if you're a regular there.
The cost of the tools you need (since you've already got a truing jig)
probably wont be paid back the first time you use them, but after that if you
use them again you will save yourself money and be confident in the knowledge
that you've done the job properly. I also find it enjoyable.
Best of luck!
d_jp | 8 years ago
Can't help on the wheel building I'm afraid as it's not something I've done, but if you want a chain whip for getting the cassette off (either for rebuilding or general maintenance) I would suggest looking at the B'Twin Chain Whip which has worked well for me & was reviewed here on road.cc
DaSy | 8 years ago
With three broken spokes, the wheel tension will have gone badly out, so you will need to slacken off all the spokes, remove the offending ones, replace with new, then re-tension and re-dish the whole thing to do the job properly.
Just putting a spoke in and winding it up until the wheel looks about right will just result in more spokes breaking, and fairly quickly due to the wild imbalance in spoke tensions.
My advice would be to take it to a shop, let them rebuild it. I used to only charge £20 to rebuild plus £1 a spoke, and for the amount of work involved that is pretty good value.
It is worth finding an old wheel, then pull it apart and rebuild it a few times, as there is a lot to get to grips with initially, such as getting the spoke lengths right, as you will usually have at least three different length spokes on a bike. getting even spoke tension and correct dish also take a bit of practice, but all very do-able with a bit of patience.
Learning to lace the spokes correctly is the most difficult initially, but once you have it sorted, building a wheel is just a simple set of routines, and a good amount of patience.
Edit to add:
You buy spokes of the exact length you need, within a millimeter, the days of threading your own spokes is mostly behind us, it is a useful skill if you work in a shop, but really unnecessary as a home mechanic.
