6 comments
There's not a massive difference between a standard with 11-28 and a compact with 12-27. Rather than change the chainset, try changing the cassette first - much cheaper. Could even go to a 11-32. Planning on going standard and 11-32 on my next bike - wider gaps between gears but very versatile
Have a play with this:
http://gear-calculator.com/?GR=DERS&KB=34,50&RZ=12,13,14,15,16,17,19,21,...
I wimped out on my new bike, I originally ordered a standard chainset with a 11-32 cassette. I then spent moths worrying about it (long lead time on the order with Rose) before deciding that I spend more time climbing than spinning it out on the flat - and switching to a compact with an 11-32.
I've not particularly noticed the larger jumps between gears (going from a 12-28 on my other bike to a 11-32). I have found the lower gearing has improved my times on some hills which I can now spin up rather than having to get out of the saddle.
If you aren't a pro and don't always ride in a group, I'd stick to the compact. You could consider getting an ultegra chainset as well; cheaper, stiffer and only a little heavier.
Buy a new crankset in the size that you want before delivery. Then remove the original one before using it and sell it. You will probably make a small loss but i'm sure the 53/39 will sell.
Oh, if the LBS are not playing ball then buy your crankset online. Their loss.
Other more tech savvy chaps will be able to confirm if you will need to change the chain length too with a 53/39-11/25 switch to 50/34-11/28.
As a numpty myself I was faced with a similar challenge on a second-hand bike that came with an Ultegra 53-39t chainring. I fitted a 12/32 rear cassette which gave comparable gearing to my usual compact set + 11/28 which a) was a significantly cheaper option at circa £25 and b) fortunately didn't require any other modifications to the running gear.
Maybe that could be an option worth investigating?
Edited: Ignore my crap advice, the biggest cog the rear derailleur can handle on Dura Ace is 28
If it's a shop they could probably sort a chainset swap without it costing you (much) money.
Yes it's a shop, but they seemed reluctant to offer any assistance, which is probably a sign that I need to look elsewhere.
