4 comments
You're about the same weight as me, so one thing to bear in mind as I also have the elites is that the narrow rim will give you a bulbous tyre profile. That takes a bit of getting used to if you sit a bit heavier on the bike. They can often feel a bit squidgy. I found that often, the more you inflated them the worse it was.
I tried 28's on them briefly one winter but it was too much and made me feel uncomfortable cornering hard.
Having said all that I've always run 25's on all my wheels..
I've remembered that I have a set of 23mm Vittoria Rubino pros in the garage since posting this. Time for some experimenting.
No problem with 23mm Lithion 2s on mine.
Yes I think you will find that the tire is stiffer on a wider rim, but you can also experiment with other tires (heavier casing, stiffer tread) or higher pressure to achieve the same level of stiffness. You can also try using the narrower tire only on the front if you want to retain the milder ride of the wider tire in back.
Also, I have not personally compared those two wheelsets, but I would expect that the Zipp rim is considerably stiffer than the Ksyrium elite, which could also explain the different feel. The spoke count, lacing, type of spoke, and tension can also affect the wheel stiffness. Lots of variables!
