7 comments
I checked the drop on my current brakes. It's 49mm. So the 105s should fit ok.
The pull ratio then is the issue. If I understand correctly different levers pull different amounts of cable and brakes are set to work by these differing amounts. When pairing a 105 brake with a 2200 shifter the set up will work at or better than the standard set up I've got but may not perform at the optimum given the pull ratios are different. The brakes may also feel different or require different handling than currently, pull harder/softer etc.
Does that sound about right?
I think so, that's been my experience anyway.
I replaced the brakes calipers on my old Triban 3, when it got to the point that I couldn't stop at junctions at the bottom of hills anymore. I opted for Campagnolo Veloce. These did improve the braking performance, i.e. I could stop. However, the limiting factor is also the lever, as it doesn't generate enough force to really support decent calipers. I therefore decided 105s would be a waste of money, but the Veloce would be a nice half-way between standard & 105s.
http://www.wiggle.co.uk/campagnolo-veloce-10-speed-dual-pivot-brake-cali...
I think the 105 brakes are designed to work with a shorter pull and so are only supposed to be used with 105 (or better) levers which are designed for a shorter pull.
Still, when my rear brake seized up on my tiagra equipped secteur I installed a 105 caliper and it works fine, not anywhere near as well as the 105 brakes on my 105 equipped CR1 pro, but fine.
My Triban just about took Crud roadracers. I ended up taking them off as they rubbed a lot. I dont think there'd be room for proper mudguards.
I'll measure the drop later and report back.
As I recall, the Triban 3 has clearance for mudguards, so you'll need longer drop brakes than standard 105s. Sheldon Brown has images showing how to measure the brake clearance you need if you're unsure. If you want to stick with Shimano, go for 451 or 651 brakes. Ribble have them both at a good enough price that you may as well do front and rear in the same job.
To replace the front brake you'll need to undo the captive nut behind the fork. As I recall it uses a 5mm Allen key. Stick the key in the back and undo the nut. Pull the brake out of the front and then use the Allen key to post the nut out of the back o the fork.
Yes. You can put any brakes on there. I've heard ultegra are super good. But I'm a campy/ SRAM rider.
