3 comments
Thanks guys, that's very helpful. I'd started to think that 38-47 would be about ideal for me so it's good hear some positive feedback from people with some experience. I don't think I'd want to mess with my position though, aero as it is.
I quite regularly cycle over the Severn bridge and can be leaning sideways into the wind just going straight with my current wheels, it would be nice to be able to use any aero wheels for some routes into Wales.
Is there much difference in terms of cross wind stability with the new wider U profiles are they pretty much the same as the narrower Vs?
im 70kg and i feel my front wheel going a bit on 30mm rims, just the way it is, i cant imagine itd make that much difference being a bit deeper for crosswinds.
If you do get the aero rims and find that they are bothering you in wind, then you could use a shorter stem on your bars as that will increase stability, but then you risk increasing air resistance on your torso. Its important to get your upper body as aero as possible as thats the largest surface area.
Depending on how deep you decide to go on the rim will determine how much you may be effected by buffering in strong crosswinds. You'll regularly see rims in the region of 40mm depth used in a lot of conditions (flat, hills and wind) and by light riders with little problem. It's a popular depth as it provides a versatile wheel, fast on the flats, competent on the climbs and still manageable in the wind. If you start going beyond this e.g. 60mm-80mm or more then you'll have to be more mindful of the wind, especially if you're light and it's particularly strong.
To put it in perspective, I live close to the New Forest so it's open, flat and can be rather windy. I'm probably on the lighter side of things at 60kg and have little concern with the 40mm rims that I use practically all year around. I'd be confident of using 60-80mm wheels in blustery conditions (it may not be so much fun) but there's still controllable. If it's crazy strong wind out then there's a good chance, whatever wheels you're using, you want to consider how safe it is to be out on the road anyway.
Hope that helps. Stay well and ride safe.
Mike
