11 comments
several levels of shimano over the years have all done this until ... mud guards
got fitted. keeps the salty grime away from the brake (back is the worst affected
for obvious reasons).
yes i know "mudguards make my bike look shit" ... but saves a few bob too
Form over function I'm afraid!
I'd rather replace the calipers every couple of years than fit guards!
I've got 2010 "thumb shifter" Sora on my Caad 8, and just swapped the Cannondale own brand callipers out for 105 5800 callipers, the braking is awesome now, only £24 each from either wiggle or CRC. Dont spend too much time or money on your old ones, the new 105 brakes are awesome and work amazingly well.
This should help ease some of the confusion
http://www.celebrazio.net/bicycling/shimano_compatibility.html
That's a useful link, thanks.
Yeah, it has the bolt to the side of the fixing bolt which is a bit corroded. After the weekends' sportive I'll have a go at dismantling it.
Does anyone know if a 105/Ultegra caliper is compatible with a Tiagra STI?
From mixing all sorts over the years, you may not get the "best" performance but it will work.
I can't remember what a tiagra looks like, is there a bolt to the side of the fixing bolt? what happens in the winter particularly is that salt corrodes the bushing on which the arm rotates. Basically what you need to do is dismantle the whole caliper and clean it, doesn't always work. If you see corrosion gentle sandpaper it awy, then grease all the pivots before reassembly.
What I did do on an old set of Campags was loosen the pivot bolt which helped in the short term.
http://www.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/BR...
I know it is ultegra, but it is close enough to guide you if you decide to strip them down. It isn't hard, just watch the spring can be a pain sometimes.
As I said it's not the cables.
The Calipers themselves appear corroded around the nuts. With the cable entirely slackened off it's a two hand job to pull the calipers apart to the full range of their motion.
Agreed about the cables. I bought a Genesis with Tiagra kit, the brake 'action' was rubbish ( I should have taken it back to the shop straightaway, didnt cos I was enjoying the ride), the movement was not smooth at all. First thing I did was putting GT85 down the inside of the cables which made things better. Then I changed the outers and inners, problem solved. I worked out it was the cables after disconnecting the brakes and moving the calipers by hand which was smooth. Also while the brake cables disconnected I made sure the lever movement was smooth (which it was).
Sounds like it could be a cable issue to me, remove, ran and degrease the rear brake cable and check for corrosion, this should fix it.
If not completely remove the brake caliper. Then remove brake blocks and deep clean the caliper, getting all the inside faces and cycling the calipers through their range of movement. This will reveal lots of well hidden nooks and crannies that attract dirt.
I was just looking on Wiggle, is the stuff around leverage ratios saying that you need to match the caliper to the STI - i.e. ultegra shifter for ultegra brake?
