11 comments
It happened to me twice, once on a gentle descent where I discovered a new max heart rate trying to stay on a wheel over the top of the preceding climb in a race in Mallorca, and once on the flat at the end of a long line of riders in a big kermesse race in Belgium. Way, way out of my depth on both occasions.
Contrastingly, my mate placed well in a UK race after snapping his front derailleur cable, so 39-12...
Regarding the topic of the thread however... its all been said. Push your cardio vascular system and spin gears, rather than push hard on the pedals.
What turbo are you using, and where are you measuring power? If you are measuring power off the turbo, you may find that the machine actually reads differently when you are using a bigger gear than a smaller gear.
The problem (its not really a problem) with power monitoring is that its not necessarily perfect. A machine monitor force applied to an area of the drivetrain, measures cadence and makes a calculation and interprets that into a number. As long as that number is consistent to itself, you have a wonderful training tool, however the number is not necessarily absolute fact all the time.
Good points I will check my cadence i think from memory i was above average probably 95ish. On the road i average 89rpm every ride pretty consistently but on the trainer in the big ring i struggle to maintain that. Not 100% sure why i'm probably trying to push too big a gear i will see what i ride in at the weekend and then on the trainer.
Having more numbers to look at can be a little obsessive!
thats the point ha ha
I now can spin 100 plus on small ring up hills but not he flat I get into the big ring and spin at 85 or so, it is all up to personal preference. I am not a racer but the point made about that is of course totally valid !
This is sensible advice, but it only goes so far. The reason racing bikes have big rings and small sprockets is because they can be ridden fast, and there is no point being able to spin a small gear at a high cadence if that sees you spinning merrily away out of the back of the bunch. Cadence is one part of riding; the other part is power, and you need to work on both to be a fast rider.
The scary part comes when you are spinning out a 53-11 gear combination while trying to hold the wheel in front of you...
You mean cadence and strength. Power is a function of cadence and force applied to the pedals.
To go faster you need to push harder or spin faster. It's ideal to have both, so you can take some load off the muscular system by spinning and placing load onto the CV system, and vice versa. you should train both by over/under gearing on training sessions for intervals.
Scary for me around here as I would i'd be doing nearly 80km/h...
Na... probably about 40-45mph. Its different spinning like a loon on a down hill, another when its on the flat... it quickly tires the legs I can assure you..
An amazing feeling though, when you are trying to click to the bigger gear and there aren't any... when you are pushing the pedals as hard as you can just to stay in there and its on a flat road. Epic. The trick of course is to move up!
I spin out somewhere between 125 and 130 (i'm no track cyclist, that's for sure) so that'll be between 75 and 80 km/h on 622-25mm using 53x11. So that's between about 46 and 50 mph. Downhill ? Yeah, that'd be do-able with a reasonable bit of distance. On the flat ? Nah.. not me. Not for quite a lot of people i'd reckon, for any non-trivial amount of time - you must have legs and lungs like a monster
yep agree with that as you train more and more you move from little ring to big ring and I can now spin at 95 int he middle of it for 10 mins, something impossible a month ago.
I was told a tip which helped me no end, always ride outdoors on the small ring as it keeps the cadence up and cadence is the key.
It's where the work comes from.
In your big ring it's from more force and lower cadence, on your inner ring effort power was achived by a lesser force but higher cadence.
Remember power is the rate of doing work, not just work.
If you do some testing you'll find you generate better power and fatigue less for a given cadence, there is no 'rule' for this, it is induvidual, but you can train to spin more etc
