8 comments
You need to go up to 11.
Well, it's one faster, isn't it? It's not ten. You see, most blokes, you know, will be riding at ten. You're on ten here, all the way up, all the way up, all the way up, you're on ten on your bike. Where can you go from there? Where?
Nowhere.
What we do is, if we need that extra push over the cliff, you know what we do? We put it up to eleven.
One faster.
no you don't because its all about ratios not amount of gears. a 12-25 11 speed will not allow you to go as fast as a 11-28 10 speed.
It down to number of teeth on the lower and higher sprockets that determine how fast you can go etc
True - if you can push the bigger gear up to the same cadence. For the vast majority of non-pros it is pretty academic, if you can spin out on the flat (say 120 rpm) on a 50-12 then fair play to you (thats about 40mph). If its so steep you are spinning out, you probably aren't adding much to your speed and and you are probably more concerned about the corners. More than anything I think the benefit is that every shift is a little bit smaller and so likely smoother. But I am all on 10 speed and 9 on my winter bike, so what do I know?
it is very useful having smaller gaps between shifts. e.g. a 10 speed 11-28 wouldn't be as gradual as an 11 speed 11-28 cassette. However it depends if you use the 11 cog or even the 28 cog. If you stay in the middle, then a 12-25 is your best bet in 10 speed as it will still give you great progression.
I think I'm going to upgrade to 10 rather than 11 as i don't think it is worth the hassle of changing my wheelset.
Something tells me not everyone gets this Farrell, but as my father would have said, you can't educate pork.
correct
Look no further than 11speed 105. Significant step change in performance across the range.
I'd suggest upgrading brake pads however as this is an area where I found the 11speed 105 brakes lacking. A pad choice (about a £10 spend) provided more bite, so challenge overcome.
As mentioned above, wheels are the only bug bear, however, you are going to find it hard to obtain 10speed freehub wheels fairly soon, so you're simply storing up trouble for later.
That said, my bike industry mate is adamant that a 10speed cassette will work fine with an 11speed set up. Maybe worth a try.
10speed 105 feels more solid and precise than 9 speed Tiagra and Sora I've used. However, some say the shifters are a bit draggy.
11speed 105 feels lighter than 10speed but still precise and solid. If you already have decent wheels, then I'd probably go 10speed. If you were going to upgrade the wheels, then I'd go 11 speed.
I'm not sure if a 10speed chainset would work with 11speed, but I've mixed 8 and 9 speed stuff on the mountain bike before now.
