10 comments
I've written this a few times but it may depend on the trainer you use. I have a Tacx Bushido and I use my normal/best wheels and tyres without any wear problems. I train on the turbo four times a week but I imagine some trainers generate more heat, which is the real problem, at the tyre than others. I run either Vittoria CX tubulars or Conti TT clinchers with no problems.
I would give it a go and you should see pretty quickly whether you are getting excessive wear. My old trainer created quite a bit of rubber 'dust', which was noticeable.
Buy some rollers. Bike on bike off, easy. (And helps maintain core strength//balance)
An alternative option is just to run a cheaper tyre on the back full-time and just drop your bike on an off of the turbo as and when you need to. Keep a nice tyre up front where you will feel some benefit.
Most turbo trainers don't shread tyres that fast and £10-£15 will get you a tyre that will perform well for commuting and fare OK on the turbo too.
If you are racing and want the fastest (most expensive) tyres going then a dedicated wheel makes a lot of sense but it seems a bit overkill otherwise.
I just use my old tyres on the turbo and get as much wear out of them as I can. Don't bother with the expense of trainer tyres!
Brilliant, thanks for all the advice, will ask Santa for a cheap wheel and use my cassette (due for a change) and get on it. Cheers.
I brought a Schwabe trainer tyre for £40 and still going great after about 1.5K on the TT. No need to buy a separate wheel is there, as well as the cost it gets you practising inner tube changes, I can now do the exchange in under 10 mins
Buy a wheel and tyre. It makes it so much easier.
Whole-heartedly agree with this. If your LBS can't help, you should be able to pick up a cheap rear wheel from eBay, bikeradar, gumtree etc quite easily especially as it doesn't need to have much left on the brake track (beyond structural integrity).
I bought a cheap rear wheel from decathalon, put my old cassette on it and mounted the turbo tyre on this.
The good news: I can swap the wheel in about 10 seconds and be ready to go.
The bad news: I now have NO plausible excuse to justify why I am not using my turbo trainer.
Your 2 choices are: buy a back wheel with a trainer tire on it, or buy just a trainer tire and remount your road wheel and mount the training wheel before each session. A road wheel will destroy itself pretty quickly on a turbo trainer. No way to place trainer tires over the top of a road tire. It is not wear on the road tire, it is the flexing and heat buildup in the tire that destroys it.
