Rear brake a casualty of the winter?
by ctznsmith on January 27, 2010 - 12:31
So having cleaned my commuter for the first time in ages (and since it was covered in road salt in the last few months) my rear brake has decided it doesn't want to 'spring back' off the rim after the lever is pressed.
Also the brake lever doesn't come back (flat bars) and when you manually push it back to where it should be the cable outer moves.
Is it time for a new cable/outer?
(I've tried working a bit of oil/grease down the cable outer to lubricate the cable movement)
Is there also something wrong with the spring tension in the rear caliper if it isn't 'springing' back?
Sounds like youve identified the problem, rusty cable. You could pull the inner out, give the outer a good blast with GT85 and refit the inner with generous helpings of waterproof grease... but a new outer/inner is only a few£ at a bikeshop. Oh, and your brake should 'spring back' if that is the problem, if it dosnt then that might need stripped/cleaned/lubed too.
STATO's picture
posted by STATO [263 posts] 27th January 2010 - 13:07
Think it might be a bit of both...glad I knew the reason why, just need to find some a gap to spend some 'quality time' with my bike. Wink
ctznsmith's picture
posted by ctznsmith [93 posts] 27th January 2010 - 14:23
Some brake cables are stainless. I try to use them, having suffered from this problem many times.
two wheels good; four wheels bad
posted by cat1commuter [1003 posts] 27th January 2010 - 17:48
My bike has developed the same problem this week....
Blackhound's picture
posted by Blackhound [355 posts] 28th January 2010 - 22:51
Calendar
