13 comments
not a cheap option, but cheaper than a Zafira pump i'm guessing, take a look at the Wahoo Kickr.
output in watts, segment mirroring, a whole bunch of tech tricks it can do, and surprisingly quiet. I use it outside the house in the yard and my grunting is louder than the machine!
Trainerroad.com basically provides a cheap power meter on your turbo, by combining a turbo, a computer (logged on to their site), a cadence sensor and an ANT+ USB stick (these last two bits aren't expensive). So you can complete structured training sessions to maximise the benefit of your time using the dreaded thing. However, the big BUT is that trainerroad needs to know what the resistance looks like on your turbo, in order to estimate your output wattage for any given resistance/revs etc (since each product is different). So the site has calibrations (or known power curves) for a whole bunch of turbo trainers. Hence, if you draw your shortlist from there (there's a big choice, it's not a shortlist at all!) you'll have loads of potential for doing workouts with real goals to them and hopefully not get so bored.
Have fun! (Yeah, right!)
Elite hydrogel seems decent. I think you need to draw your shortlist from the ones listed on trainerroad as having a known power curve. That way, the tools are available to alleviate the boredom.
"A known power curve" ? please explain....
Cyclops Fluid 2 moves to the top of the list
Screw it, get a winter bike instead.
Do not worry I commute all year round... I have just invested in some wet weather cycling boots (Partly because the Zafira's diesel pump is f***ed )
The plan is some fairly scientific training
I've got a Cyclops Fluid 2, its very very quiet and in combination with 42" plasma, appletv/satellite receiver and a handlebar height laptop running Peripedal gives me a good workout with sufferfest. Not the cheapest - but its built to last and so quiet I can listen to music without waking the tiddler.
Thanks; that writes off the Lemond then!
Any votes for the Tacx range?
I have the Blue Motion which I use with Wattzap for power, analysis and virtual rides. I don't use the variable resistance on the Tacx but set it around midday (for my power output) and use the gears to vary resistance.
That said, I would probably go for the Cascade Fluid Pro Trainer at 149 from planetx as I think fluid trainers provide a better indoor ride.
Whatever don't bother with an expensive VR trainer, do use some software to help you train.
I have the Lemond one and would recommend it with one proviso. It's very noisy. No really I mean it. Think carefully if there is anyone around
It doesn't really matter if a turbo gives an accurate power output, more that the readings are reliable/repeatable so that you can monitor improvement.
It'll never be like riding on the road, and a decent flywheel won't alleviate the main 'problem' which is boredom.
Trainerroad and/or Sufferfest make turbo sessions more entertaining.
Is the Lemond one where you take the wheel out and use sprockets on the turbo? That seems more faff than a regular one if so.
What about some rollers? They're fairly entertaining cos you need to concentrate to balance. And ones with resistance still give a good workout.
