My MTB is heavy and old and needs replacing, but now I'm used to road cycling I like going fast on a light bike. Off road I'm more interested in single track trails than steep descents or rocky ground. Wondering if I should go for a lightish hard tail, or a cross bike. Any views or the pros and cons?
8 comments
jollygoodvelo [1606 posts] 2 years ago
Descents are fine, it's ascents that may be a problem on a CX bike - the lowest gears are nowhere near as low as on an MTB so you will end up hopping off and carrying the bike up hills. In a CX race that's exactly what you should do as it's quicker to run up a hill and then remount, but it may get a bit tiresome on a leisure ride (I know that when I'm off-road on the CX there are some routes I simply avoid because I know I won't get up them).
You may well find that a hardtail 29er bike is ideal for you - 29ers roll fast, and they're available with better geometry these days so you shouldn't find manoeuvrability a problem on singletrack. Bear in mind that a CX bike will have 700c wheels which are the same as 29er anyway - 622mm.
crazy-legs [850 posts] 2 years ago
Depends on the climb. There's very little in the Peak District that I can't get up on my CX bike (34-30 lowest gear). You just climb differently - more out of the saddle than sitting there spinning.
I really like my CX, it's pretty much my go-to bike for most "normal" off-road rides, I'd only ever take the MTB if it was involving some properly technical terrain.
Pros are that I'd go further/faster on my CX since it's easy to mix even fairly long sections of road in with it. Cons are that I'd avoid the really technical descents.
antigee [377 posts] 2 years ago
I run an MTB "touring" chainset on my (non racing) CX think that's a 48 36 26 with a 32 at the back pretty easy if slow on steep (25%) hills - old 9speed triple so a bit dated a 10 or 11 speed CX compact and 30 or 32 at rear will give some good hill climbing capacity
CX is great on single track and roots - post says not rocky stuff - that's good because rigid forks, narrow tyres and high stand over make rocky stuff too hard work on the downs and tricky on the ups - at least for me
A bit evangelical but if you like road and singletrack and like to connect them up a CX bike does it and does it very well
joemmo [1164 posts] 2 years ago
CX bikes are fast and great fun if the track is relatively smooth, gravelly or just stony. Once it starts getting rocky and rooty (this is not a scientifically accurate measurement of trail roughness BTW ) then the riding position, rigidity and relatively narrow tyres will start to hinder rather than help. Personally, IMHO I would get a fast, light 29er hardtail. Put up with the slightly slower speed on tarmac but enjoy the increased fun off road. You have a road bike for road so this would mean you have all options covered.
I've had a bit of a MTB renaissance recently - ironically because my cx bike is stuck in the workstand with some technicall issues - and had forgotten how much fun it is having a bike you can batter over all sorts of terrain.
beekie1 [7 posts] 2 years ago
I've just this morning dropped my old mountain bike in at the bike shop, and am the proud owner of a shiny new X bike. Having got used to the speed and position of a road bike, I couldn't face the slow squidgy feel of a mountain bike. On the downhills, sure, it has an advantage but on the flat and the uphills I just ended up annoyed how slow it was. The X bike is lovely by comparison.
The applicable phrase here is 'horses for courses'.
BBB [447 posts] 2 years ago
Rigid mtb with drop bars. With fast xc tyres you'll be able to keep up with roadies. At least based on my experience...
tomturcan [66 posts] 2 years ago
Thanks for all the comments folks, very interesting and helpful.
