hi, I'm riding a cannondale caad 8 Claris and I'd like to change the rear cassette from the 12-25 to perhaps a 11-32 or similar to help me with the hill climbs.
is there a cassette anyone could recommend which would be a simple re-fit
cheers
tony
5 comments
Dapper Giles [69 posts] 3 years ago
http://www.wiggle.co.uk/shimano-cs-hg41-8-speed-cassette/
The one above should fit but I think you will need a longer chain and derailleur.
DrJDog [416 posts] 3 years ago
you should be able to fit a cassette with a 28 cog without changing the derailleur. 34 28 is a pretty low gear...
tony18 [4 posts] 3 years ago
many thanks guys, i'm hoping not to have to change the chain or derailleur if possible so if i can get to 28max then so be it.
right, i'm getting somewhere with this.
my derailleur is a shimano rb2400 which is good for 32t max.
i've sourced a 11-30 cs-hg41 11-30 on wiggle, which will be good, however i expect my chain will not be long enough, it's a kmc z89.
how do i find out exactly which chain to get?
Chains are different widths depending on amount of gears on the rear cassette. 8 speed chains are thicker than 10 speed for example.
So search for the same model, you can probably find it on Wiggle. Their Q&A section is normally pretty helpful so your question might already be on their.
