I just upgraded my wheels to a brand new set of Mavic Ksyrium SLS. They are considerably lighter and look really cool. The only problem is my Garmin cadence sensor doesn't fit the bladed spokes on the Ksyrium. They will fit towards the end of the spoke-just before the spoke meets the rim, but the cadence sensor housing that sits on the chain stays begins to rub the tire when I move it forward. Does anyone have any solutions out there? Thanks!  103
7 comments
lisa76uk [52 posts] 4 years ago
I bought a set of these, slim and work perfectly... http://www.ebay.co.uk/itm/Discrete-MAGNET-Package-for-Cadence-Speed-Sens...
Shep73 [211 posts] 4 years ago
Do you mean the speed sensor? most companies supply one that has a keyway slot to fit a bladed spoke. If you have another one that is bladed that will work.
wellcoordinated [206 posts] 4 years ago
Try mounting the cadence sensor hang in down under the chain stay. This way you can get a cheap rare earth magnet and put it in the peddle spindle to activate cadence sensor and the spoke magnet will be close to the rim. Here a picture to give you an idea. You can see the speed sensor next to the valve and you can see the magnet hanging onto the peddle spindle.
dreamlx10 [234 posts] 4 years ago
Spelling ?
Paul J [950 posts] 4 years ago
That's a very thick rare earth magnet! You can get ones that are just a few mills thick, and will almost sit flush in the depression of the pedal spindle. They're so powerful, they don't need to be big/thick.
It is only a few mills think; about three if I remember correctly. You can get thinner ones but with that bad boy I can screw up that cadence of my fellow rides  21
Dibbs [4 posts] 4 years ago
The Garmin magnet clamp has two choices, one for round spokes and the other for flat spokes, if space is a problem Mavic do low profile magnets for flat spokes.
