41 comments
Fatigue needs two things to do damage to a structure:
1/ repeated cyclical stress
2/ a stress concentration
So if an item is unused it won't fatigue, it might corrode, but it won't fatigue.
So time limits set by manufacturers are probably based on moderately heavy usage to suit their insurers. Stress cycles close to the failure load of the structure cause a lot more fatigue damage than smaller loads so they probably make adverse assumptions regarding rider weight and road smoothness.
Stress concentrations can come from 3 sources - Poor design, manufacturing defects and corrosion. Poor design is pretty rare these days as the risks are well known. Many fatigue failures result from manufacturing defects, and these mostly come from welds, getting a weld right is not a trivial task and all kinds of defects can lurk unseen in the body of a weld and these defects will often be in the form of cracks which generate stress concentrations at their tips and you get fatigue. Castings reduce the risk of defects but a poorly executed cast can also contain defects, if you are looking with suspicion at your stem following this conversation the manufacturing process with probably the smallest risk of fatigue is forging - but you normally pay extra for that.
Corrosion can generate changes in profile and cause cracks so even if the corrosion has not resulted much loss of material it will increase the risk of fatigue damage.
By the way I ride a bike with a welded 2 bolt stem, but it's from a reputable manufacturer who I'm sure will have engineered the weld and have appropriate QA procedures that will significantly reduce the risk of a defect that's likely to result in fatigue damage
So the mistake I made was to purchase AND use the stem?
And are you saying ITM are not a reputable manufacturer? Controversial.....
I started building custom wheels recently so have learned a thing or two about liability, as well as real shelf life of bicycle components.
All the bits on your bike fall somewhere on the weight/ durability spectrum. Older stuff, like quill stems, were very durable, but the industry ceded durability for weight in the 90s. These days you can buy a bike for not a lot that's half the weight of Bernard Hinault's bike, but I can guarantee it won't last as long when subjected to the same use/ abuse.
Stems are much the same as spokes (and anything else); they have a certain number of cycles they can tolerate before failure. 10 years for an alloy stem may be a long time, but it's more dependent on the use you've put it through in that time.
2 years for a stem is legally right; almost all people will not put a stem through enough abuse for it to fail in that time. Beyond that and it becomes a matter of rider weight/ road quality/ weather exposure. Chances are a stem will last a decade if ridden on smooth roads by a light rider on sunny days, but from a liability perspective you can't guarantee that and so have to mandate a shorter shelf life, so you don't get sued if your product eventually fails and causes an accident.
- coincidentally was checking out stems on Rose's website earlier today and came across the following advice:
"For your safety, please change aluminium stems and handlebars after two years or 5000 km at the latest. After a fall you should change these parts immediately."
Does ANYONE do this? 5000 kms? !!!
Designed to allow manufacturers to avoid liability. Hard to know if it would work (how would you ascertain whether distance had in fact been reached) and not - so far as I am aware - tested, but I imagine they'd try it on (or their insurers would).
I have got one of those bikes that are 30 years+ old (honest ) but where I have changed everything on it at least once. The last thing I changed was the aluminium bars; they are now hanging on my wall
Along with an ITM stem
Great discussion going on
The only time I've ever sheared a bolt head was when using a torque wrench, that was also on a stem faceplate.
Glad you survived in one piece, a 30mph tumble in the dark must be horrific.
Outside of cycling, I enjoy a spot of rock climbing and it's interesting to compare the industry response when equipment fails like this. In the event of safety equipment failure, the standard practice is to send it straight back to the manufacturers, who by and large are incredibly responsive - precautionary recalls are not at all uncommon. SRAM hydraulic brakes aside, cycling manufacturers seem less bothered?
I remember these ITM 2 bolt stems failing about 10 years ago, the bolts were gash and there was the torque vs thread friction issues.
I have been lucky for 10 years?
Possibly, I just remember reading about it before, though they werent the only ones, I've no experience of it myself.
I'm using a 20 year old titanium quill stem on my road bike.
Not quite happened to me, but my clubmate's stem faceplate cracked. Luckily I happened to notice it when we were stopped, so a careful ride thereafter, no swinging out of the saddle. Stem binned.
I've had a nosebolt go on a Cinelli 1A stem, but that was due to overtightening. Very hard to get them tight enough to stop the bars moving if you hit a hole. After such an incident I wanged it up. Next day, speeding throguh some village in the Ras - BANG - bars shoot round and flop sideways. Lucky to stay upright there.
That's exactly what it is a cure for, do bolt up to specified torque, then stop.
Not, tighten, tighten, tighten, and then a bit more till you think you got 11.8Nm
The thing is most people don't realise just how little 15Nm and less is, especially when they're swinging off the end of an XL length Allen key.
You can even get the ones that stop going beyond the set torque if you're really stupid/hamfisted.
I have never had a stem fail on me or a bolt snap (for now touch wood), I also have never used a torque wrench on ally or steel stems.
With the exception of carbon where it is critical to get it right with a torque wrench I would be of the opinion that if you don't have the feel for getting it right yourself with just an alan key then perhaps you should be taking it to the LBS rather than doing it yourself.
I await the storm of pedantic rage but be honest chaps, buying a torque wrench is not a cure for being cack handed.
When you design a bolted connection like stem / bar joint you calculate the tension in the bolt that gives you a strong enough joint. The problem is that measuring the tension in the bolt is pretty tricky without special equipment so the most practical thing to do is measure the torque you impose on the nut or the bolt head as a "proxy" for the actual bolt tension. The problem is that it's not very accurate! It's a classic first year engineering degree lab to torque up a series of bolts in different conditions and then measure the actual tension in the bolt. If I remember correctly it's about +/- 25% accurate. The problem is that friction in the bolt/nut system eats up the torque and very little is used to actually tension the bolt but the friction in the system is also very dependent on condition. Some factors include, bolt & nut material, type of grease used (if any) location of the grease on the bolt, foreign bodies & corrosion. If you don't replicate the conditions the manufacturer assumed when they worked out the recommended torque you could be a long way out from the bolt tension intended. And of course we are all using calibrated torque wrenches aren't we? So Dr Fabulous0 when you torqued up to the manufacturers recommendation you may well have prepared the bolt better the manufacturer expected and so didn't reach the required tension.
I love this kind of stuff. Genuinely. I wish I knew about engineering.
Careful Jellysticks who you say things like that to - most engineers can talk for hours about this rubbish if you let them - Let me tell you about inviscid hydrodynamics......
Maybe *that* is what Chris Froome is doing?
http://chrisfroomelookingatstems.tumblr.com/
ITM Millennium!!! Isn't that over 10 years old? I think that, right there is your problem.
Truth is the stem/bar interface is never going to be that brilliant from an engineering point of view... but things have moved on significantly from those Millennium days.
Muchos kudos for simply taping your bars back on and riding home... that is truly hardcore!
Get well soon.
Mind you, it was a choice between ringing 'er indoors at silly o'clock for a lift home..... or risk death with taped up bars....
Not much of a choice really
I've noticed quite a few of the pros riding one-piece stem/bar combinations recently. Seems like a far more sensible approach to me.
Oh dear, you've got me worried about my 40+ year old bike on which I'm planning to ride the Retro Ronde.
Will it fall apart on the cobbles? Is there any way to check, short of ultrasonic inspection?.
Looking at my 30+ year old bike/stems they are very solid looking and look better engineered than this relatively modern stem. I have never known one ancient or modern breaking. I am reassured that no one seems to be saying, "This has happened to me...."
Suggests I am just unlucky...
I have to admit I did not use a torque wrench, but I am not a ham fisted bugger. Obviously they could have been over or under tightened. But as I have said they have been fitted for some time. I am wondering if the bolts could have become brittle through use? Work hardened? So maybe I should have changed the bolts?The stem is an ITM Millennium, but now it has broken I think it looks a bit flimsy...
Thanks for the responses
When I used a torque wrench for the first time I was very surprised at how little pressure the 4 to 6nm most stems (in fact most bicycle bolts) spec is. If you've never used one, there is a good chance you will be surprised at how much you are over-tightening everything on your bike. It's worth having a quick shot of one to get the feel.
I had a stem faceplate fail once due to corrosion, it'd done a couple of harsh winters.
A big tug on the bars pulling onto a roundabout at rush hour and the faceplate disintegrated leaving the bolts in situ. Luckily I rode no handed across the roundabout like a boss carrying the bars, more luck than judgment mind
Would you be able to name the brand ?
Two bolts is a poor design as you now realise, if they are not tightened evenly then one can be taking excessive force, four bolts or one are better. I've seen a few failures like this though, threads stripped and cracks and even once a stem shear off at the weld, luckily none of these resulted in injury but poor manufacturing quality was the issue in all these cases rather than incorrect installation.
I've been a bike mechanic for many years and I have to warn you guys not to put to much faith in reccommended torque settings, it is not uncommon to do up stem bolts to the manufacturer's specification and find that the bars will slip under a slight load. An experienced mechanic can not only make a fair estimate of torque without the torque wrench but can also feel when the bolts are under sufficient but not excess tension.
Two bolts no worse than 4: http://www.eastoncycling.com/bike/wp-content/uploads/2010/04/RD-06-2Bolt... (Although now Easton have followed the fashion to 4 bolts, suspect you can't find this paper so easily on their website anymore.)
The bigger problem is not a faceplate that is too loose at recommended torque settings but one that is overtightened by someone who doesn't have the benefit of a torque wrench.
And the bit about "experienced" mechanics being magical - leaving aside the fact that this is a fairy tale, a mechanic who doesn't own/use a torque wrench doesn't deserve the sobriquet "experienced".
So they were all rubbish before carbon came along and torque wrenches were needed?
Piffle.
It's the over complication of the subject/trade by middle class people with more money than sense, much like when they all thought they could retrain as plumbers back in the early noughties.
No it's not magical but neither is throwing money about or snobbery.
Pages
