7 comments
If it was mine I'd sent it back to Ribble. I wouldn't fettle it either as then you will likely invalidate any warranty.
I'm certainly no authority on such things, but wouldn't the 'bump' of the pad adjusting to the different distance to the surface affect the wheel stability at speed? I'm not sure I'd fancy braking from 40mph with that.
In addition, wouldn't it act like a plane to shave off the pad surface (assuming the second surface is closer than the first)?
If it's only slight then the step for the machined surface should let you get away with the abrasive pad or stone, if you are not too cack handed the finish should be fine.
The wheel seems to run true even when I'm riding it (i.e. it's under load) and the gap is very much smaller than 0.5mm. I'm more than happy to "fettle" it a bit, though I suspect doing so will remove some of the powder coating.
I think the problem is perhaps less the gap and more the step between the two ends of the hoop. It's not much, but enough to feel and for the brake pads to rub on.
I emailed Ribble about it first thing this morning but so far they've not replied (they often take a day or so)
I was just downstairs in the garage messing with break pads as I could hear something wasn't quite right with my Dura Ace 9000 C35s - noise from the back wheel when breaking. I think I better go and take a closer look. Perhaps the same guy made your wheels made mine too
It's normal in so far as rims often have this fault where the pinned joint completing the hoop is not quite true. Is it an actual gap or a small step between the two sections of about half a mm or so?
You have the choice of returning it or possibly taking an abrasive stone to it, it depends how out of true it is or if it's an actual gap.
It's the joint, and I'd question it if it's that bad to rub the pads.
Throw it back to Ribble and see what they say.
