Hi
I was wondering what people would recommend for some reasonably budget touring wheels - should I go with bottom of range CX wheels? I'm looking for 28 or 30mm tire width, not worried about weight, it's not for racing. More important that they're durable and weight bearing so 28 or 32 spokes on rear wheel.
Any suggestions?
Thanks
6 comments
Flying Scot [927 posts] 3 years ago
You should find a local wheelbuilder and ask for advice, they wont be any more expensive than factory built wheels and they will be 'yours' and usually have free true ups for the life of the rims.
If you say which region you are in, I'm sure you will get some recommendation's.
I use 'Big Al' Wheelcraft myself, have done for 25 years, other people round my way (central Scotland) do the same or use Derek at Wheelsmith.
Ambrosio rims are a favourite in this application, but your local guy will know best
MKultra [392 posts] 3 years ago
New old stock Shimano hubs are the way forward.
STXC/Deore/LX/XT anything mid to late 90's dependent on how many sprockets you want, on a good rim with stainless spokes it will be cheapish and fairly bombproof, plus you can replace odd spokes your self if you need to.
If you have road OLN then 105's of the period are nigh on identical.
SamShaw [266 posts] 3 years ago
Another vote for a local wheelbuilder, if you're looking for something proper then handbuilt is the way to go, you'll get something specific to your needs and it'll be able to be serviced/spokes/rims replaced as necessary.
7thGalaxy [44 posts] 3 years ago
Region is Wiltshire if anyone has recommendations?
rainman onwheels [11 posts] 3 years ago
dt swiss rr585 rims are pretty mega. I have them on my tandem and they are still running true after a fair bit of agro. 585 grams each though so not light  1
keef66 [77 posts] 2 years ago
Have a look on Spa Cycles website; they cater for the tourist / audax rider. I'm sure if you phone them and describe what you want them for they'll advise accordingly. (I'm considering them for some repairable winter wheels with a hub dynamo)
