6 comments
Looks like the same problem afflicting my Reynolds Stratos Pro disc hub (front) after 500 miles. Not impressed. Warranty time I think.
Thanks all for the help. I thought exactly like MKUltra has said, that there would be a grub screw or mavic style adjustment. Annoyingly it has neither! It's very frustrating as this is a really simple adjustment on the Fulcrum/Campag wheels I've used with sealed bearings. Same apparently with Mavics as you have mentioned.
Agreed that it looks spookily like a rebadged DT Swiss effort, I think the design is basically a cheaper knock off of the 240 hub, which also has no preload adjuster. Like the 240 and some older Zipp hubs, it seems to rely on the clamping force of the quick release to tighten everything together, which is not working in my case. Took it to a bike shop today, I'll see what they say!
You most likely will not be able to force grease into cartridge bearings as they have sealed by dust covers. As others have said some use a grub screw that you undo, shuffle the bearing and it's locking collar back towards the shoulder of the axle and do the grub screw back up. If it's not that system it may be like the old Mavics that require you to do the wheel up in the fork with the quick release and tighten the cartridge locking nut with a cone spanner until play goes away. I would go to the manufacturers site to be sure though, look for a drawing for that hub. It's only a cartridge bearing hub which sounds a bit posh but is in fact much easier to maintain than cup and cone.
https://www.reynoldscycling.com/uploads/files/2014-Owners-Manual.pdf
Looking at the drawing it looks spookily similar to a DT Swiss hub which is a grub screw job, which is probably no accident as they make hubs for a lot of people.
You most likely will not be able to force grease into cartridge bearings as they have sealed dust covers. As others have said some hubs use a grub screw that you undo, shuffle the bearing and it's locking collar back towards the shoulder of the axle and do the grub screw back up. If it's not that system it may be like the old Mavics that require you to put the wheel in the fork with the quick release done up and tighten the cartridge bearing locking nut with a cone spanner until play goes away. I would go to the manufacturers site to be sure though, look for a drawing for that hub. It's only a cartridge bearing hub which sounds a bit posh but is in fact much easier to maintain than cup and cone as they are nearly all push fit. If you need a third hand to hold all the gubbins together while you re tighten the grub screw then again you can use the QR to do this with wheel in the fork.
I'd say over-tightening the quick release will probably just cause the bearings to fail more quickly, so I wouldn't use that option. I wouldn't have thought reseating the bearings would help either. Unless the whole sealed unit is loose, any play that has developed will be between the bearings and races.
You can try and force some grease into the bearings to help reduce the play. Other than that, you might need new bearings, but that shouldn't actually be expensive - pop the existing ones out, read the reference number on them and search for a set on the interweb. Cycling suppliers charge a massive premium for them, but most bearings are not cycling specific and can be had for a few quid elsewhere (assuming they are a standard stainless bearing and not a ceramic one). You can often get better sealed ones too, which would give you a longer life.
I would contact Reynolds and see what they say, I have a similar issue with my track bike, but no so much as you, but the wheels have done the same distance. The advise I had from some very experienced track riders was that its ok and fairly normal, but the track and road are 2 different beasts
