Can anyone advice please,
I have a new pair of dhb knee warmers which fit really nice, but whenever I ride they slip down. Then if walking around they then slip right down below my knees.
Would this be due to the hairs on my legs? I do have hairy legs and have never shaved them, but was interested to know if shaving would prevent this from happening.
I hope someone can help.
Richard  103
 39
9 comments
Jack Osbourne snr [711 posts] 4 years ago
Nowt to do with the fur. The solution is simple enough, just buy bigger knees.
Alternatively, ditch the embrocation oil and use honey instead. Simply jump in the shower without undressing after your ride to steam the warmers off.
jengy [72 posts] 4 years ago
I'm the same, skinny knees, either buy a smaller set or take those ones in
got a sewing machine ?
Redvee [395 posts] 4 years ago
Are you putting them under your shorts or over?
consciousbadger [41 posts] 4 years ago
+1 for buying bigger knees.
Luminosity [76 posts] 4 years ago
Ditched my DHB's for exactly the same reason. Bought Endura. E Voila. problem solved (better grips)
abudhabiChris [691 posts] 4 years ago
It's just some grip better than others or fit your leg shape.
I have perfectly shaved legs and this still happens to me with certain tights or knee warmers, especially if its wet.
The bad news is that - unless you're incredibly lucky and find exactly the right holster for your guns - there seems to be a correlation between price and grip.
glynr36 [637 posts] 4 years ago
Usually found that with cheaper ones (which the dhb are), I went through a few cheap ones, including the dhb, and settled on castelli nanoflex.
Worth the case as they stick where I put them, definitely a case of you get what you pay!
Flying Scot [1005 posts] 4 years ago
I have found they will all slip occasionally,mbut good ones less likely to do so.
Best set I have are old Descente they're were £stupid though.
alexjones5 [27 posts] 4 years ago
castelli nano flex, problem solved!!
